99 528i random misfire running rich - Bimmerfest - BMW Forums
Old 09-11-2019, 01:52 PM
Agcmrjazzy Agcmrjazzy is offline
Mein Auto:
Hello everybody, I have a 99 528i and a few weeks ago it was runing like I had put racing cams in. I changed plugs, coil boots, and cleaned the maf sensor. Codes read now misfire in 3,5,and 6 and random misfire code. I know what I have done has helped some because before I did all that it was misfire on all cylinders but #2. Now when I cleaned the maf sensor I noticed up by the throttle body a hose going beside it and it was broke off. Don't know if this would cause the misfires I have now or if it is still something else.
Old 09-11-2019, 03:38 PM
Chedley Chedley is offline
Mein Auto: 2001 E39 540i
Yes, clean up the throttle body with carb cleaner, replace that broken hose, reset the adaptations.
Then test drive.
<=E39=>
Old 09-11-2019, 04:15 PM
Mein Auto:
Reset adaptations meaning what? And the intake is clean. From what I have seen it's the hose going to the idle control valve.
Old 09-11-2019, 05:31 PM
mattmar1's Avatar
mattmar1 mattmar1 is offline
Wingnut
Mein Auto: 1999 5281 5 sp msport
a pic of the broke hose or a better identification of it would help. if its a vacuum hose, this would definitely cause exactly what youre seeing. random misfire codes are often set by a vac leak.
99 528i 5sp sport
be alert...the world needs more lerts
Old 09-11-2019, 06:40 PM
Mein Auto:
This is the intake boot that goes on the throttle body. The small hose is the one that broke off
Old 09-12-2019, 06:07 AM
jbarb jbarb is online now
Certified humanoid
Mein Auto: 2003 530i E39
This ^
Like others have suggested you might as well clean the throttle body and ICV when your in that under-hood neighborhood too.
Old 09-12-2019, 01:43 PM
mattmar1's Avatar
Wingnut
oh yes one heckuva vac leak there. unsure...was it replaced? basically, the MAF tracks the amount of air allowed in to the engine for combustion. you have a post MAF air leak with that portion of the boot broken. youre confusing the system, and the 02's are trying to compensate for all the extra air coming in by enrichening the mixture, but cant, youve hit the limit, thats your rich mixture error
99 528i 5sp sport
Old 09-12-2019, 02:59 PM
Mein Auto:
New boot will be in tomorrow and I will see if it fixes it.
Old Today, 01:29 PM
towertrash towertrash is offline
Mein Auto:
I'd also check the DISA valve and all the vacuum lines in the CCV system too. Seafoam did wonders for me in all of the suggested comments
