Battery drain with top down - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series & 2 Series > E82 / E87 / E88 / F20 1 Series (2008 - 2014)
BMWs throw back to the iconic 2002, with a renewed form and function. The smallest car in BMW's line up but still packs a punch. Available in coupe or convertible, powered by a naturaly aspirated inline 6 in the 128 or the turbo twin power inline 6 rocket sled 135.
Old 09-12-2019, 08:40 AM
doane2u doane2u is offline
doane2u
Mein Auto: 135i M Sport
If I leave the top down the battery drains power and it won't start... takes about an hour or less. Any ideas what it might be? I don't have a schematic. No dome or other lights were left on.
Battery checked out good and the alternator is also good, putting out about 14v
Thanks,
2012 135i M Sport Convertible (E88) 40k miles
Old 09-12-2019, 09:02 AM
Markst Markst is offline
Mein Auto: BMW 5
One of the motors that fold the top?
Old 09-12-2019, 09:26 AM
doane2u
Does anyone have a link to the wiring diagram for this E88? I don't hear any motors running.
Old 09-12-2019, 09:43 AM
Mein Auto: BMW 5
Automatic soft top operation.
Wiring Diagram
You should probably start at the fusebox though, check the voltage difference between the fuses' legs, so you know which one is using current.
Old 09-12-2019, 02:45 PM
doane2u
Thank you, really appreciate it!
Old 09-15-2019, 06:37 PM
CliffT CliffT is offline
Mein Auto: 2008 135 convertible
I suspect that the symptoms are just masking a weak battery.
Old 09-15-2019, 09:35 PM
doane2u
It turned out to be a weak battery after all. It was just coincidence that the top was down several times. AAA had tested the battery and the indicator lens on the battery was green indicating it was good, along with the alternator being good, that really mislead me.
My mechanic replaced the battery and let it sit all day with the top up and down and there were no problems. Has been fine since Wednesday of last week. I am out several hundred dollars, but am glad it wasn't something more complicated.
Thanks everyone for trying to help
Old Yesterday, 05:46 AM
jaye944 jaye944 is offline
Mein Auto: BMW
actually it makes perfect sense, using the top, takes a LOT of battery power, then it the car stays in standby mode for around 30minutes, so yes weak battery will get killed in short order
battery, power leak, voltage leak
