Need help!! 94 318i has misfire, I can't figure out. - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 09-11-2019, 06:28 PM
Danielrom Danielrom is offline
Mein Auto:
So I have a 94 318i, that I decided to do a valve cover gasket change, and figured I'd change the spark plugs while I was at it. After the job was done, I fired the car up, and it idles terrible, and the engine the lob sound. I looked back over the cables and the #1 cable had a tear in the boot and would shock me when I touched it. I got a new set of spark plug wires, which did not fix the problem. I did the stomp test and the only code it gave me was 1226(#2 knock sensor). Ive exhausted my knowledge on the subject, and don't know where to look next. I used spec torque on the spark plugs, and from what I can tell all the wires are getting spark to them. Any direction is greatly appreciated!
Old 09-11-2019, 07:51 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
My guess is you've got the wires crossed up. Been there, done that on my 318. Embarrassing, but easy to do with the weird way BMW routes the wires under that cover.
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 09-11-2019, 08:00 PM
Mein Auto:
I've got them going 1234, starting from the forward most cylinder back to the rear of the engine. As far as I can tell that's how it was before I touched anything. Is that the correct sequence?
Old 09-11-2019, 09:21 PM
D'oh, You Kids!
That's right as to which cylinder is which, but how about connecting to the coil pack? Do you have a rectangular coil pack, or a square one?
Quotes to live by:
BMW-CCA #441426
Old 09-12-2019, 04:02 AM
Mein Auto:
Rectangular coil pack, I have it in the same order on there too, starting with 1 for most and then 2 moving back. I've taken the wires all off and put them on one by one just to make sure they are in the right order.
Old 09-12-2019, 05:53 AM
D'oh, You Kids!
There's your problem. The coils are not numbered 1-4 from front to back. They are 3-2-1-4 front to back. Try that.
Quotes to live by:
BMW-CCA #441426
Old 09-12-2019, 09:05 AM
Mein Auto:
So on the cool pack, the forward most post connects to the wire going to the 3rd cylinder?
Old 09-12-2019, 09:30 AM
D'oh, You Kids!
Correct! I told you it was weird.
Quotes to live by:
BMW-CCA #441426
Old 09-12-2019, 09:31 AM
Mein Auto:
I'll give it a shot.
Old 09-12-2019, 04:32 PM
Mein Auto:
No luck. I tried it with the forward most plug, going to the 3rd post on the coil pack, 2nd to the 2nd post, 1st to the 3rd post, and 4th to 4th post. It made it run worse, but when I moved it back to the 1234 positions it improved slightly. Still lobbing and shaking a lot.
Old 09-12-2019, 04:59 PM
cmybimmer's Avatar
cmybimmer cmybimmer is offline
Registered Non-OP
Mein Auto: 5wagon
Are you sure the coil packs are good?
-Usama
1994 325is (2006-2010) -- 1989 325i M50 Swap (2011 - 2014) -- 2001 525iT (2018 -Current)
Old 09-12-2019, 05:01 PM
Mein Auto:
As sure as I can be. I've got two of them now, and they both do the same thing. It's getting spark to all the plugs. Do you think the ecu, was damaged or something like that?
Old 09-12-2019, 05:06 PM
cmybimmer's Avatar
Registered Non-OP
Mein Auto: 5wagon
I doubt it.
What kind of spark plugs did you replace them with? I remember on one of my e39's I changed the spark plugs and the engine ran like crap. Ended up putting the old one's back in until I could get another set from another brand.
Since you only have four cylinders, it's worth a shot to throw in the old spark plugs and see if it runs like it did before you started the work
-Usama
Old 09-12-2019, 05:12 PM
Mein Auto:
Well I changed them to the pre gapped ngk's that I read on the forum was the ones to get, but I changed them back to the old ones that are adjustable. They now also didn't work, I tried a new set, that's like the old set, but no luck. For the sake of trouble shooting I've got the old set back in since they are proven.
cmybimmer's Avatar
Registered Non-OP
Mein Auto: 5wagon
And Sorry Ken, not to disrespect or anything.. But a quick google search I came up with this firing order for the m42 (1-3-4-2)
PS: I know nothing about these motors
-Usama
Old 09-12-2019, 05:14 PM
Mein Auto:
I'll give that a shot too.
Old 09-12-2019, 05:22 PM
Mein Auto:
No good. She really didn't like that, lol.
Old 09-12-2019, 05:37 PM
cmybimmer's Avatar
Registered Non-OP
Mein Auto: 5wagon
Interesting, was that knock sensor fault there before changing the VCG and plugs? Could be something to do with that
-Usama
Old 09-12-2019, 05:49 PM
Mein Auto:
It never had a cel before, and most of the time there's not even one now. not sure if the stomp test saved that code from before I owned the car, or if it just started. I wondered that too if some how the vcg change did something. I don't know what or how though.
Old 09-13-2019, 10:57 AM
D'oh, You Kids!
Firing order isn't the same as how the plug wires connect to the coils. If I'm wrong, I apologize, but I know the coil connection isn't 1-2-3-4 front-to-back. First time I had the wires off the coils I reconnected them like that and it resulted in some spectacular backfiring.
If I recall, the connections are marked on the coil, underneath, next to the plug wire ports.
By the way. I like your new sig pictures, Usama!
Quotes to live by:
BMW-CCA #441426
Old 09-13-2019, 11:01 AM
cmybimmer's Avatar
Registered Non-OP
Mein Auto: 5wagon
That's why I had to post that disclaimer that I know nothing about these motors
Never worked on these motors, nor did I have a car that had one so your input is worth more than mine
-Usama
Old 09-13-2019, 03:35 PM
Mein Auto:
So today I tested each plug wire outside the engine with a spare plug, and all 4 had good spark. I ordered a 3rd set of plug wires also. I can't see how it's anything other then, wires or coil pack.
Old 09-13-2019, 03:45 PM
Mein Auto:
The order of plugs on the coil pack is 1234. Unless the new coil pack and wires are also messed up like the old ones. I don't know what to look at next, with the car.
Old 09-13-2019, 07:12 PM
D'oh, You Kids!
I'm glad you got that and it has the plug connection ON the coils. Mine was different....it gets a bit confusing since there are at least 4 different coil packs for the M42/M44 engines.
Quotes to live by:
BMW-CCA #441426
