Fxx-/Ixx-/Gxx-series Coding: Getting Started Guides, Tips, & Cheat Sheets - Page 17 - Bimmerfest - BMW Forums
Old 08-03-2019, 08:26 AM
Dylferguson98 Dylferguson98 is offline
Mein Auto:
Hi am looking to get the latest version of esys and launcher which currently works with token master any help would be much appreciated
Cheers
Old 08-03-2019, 07:54 PM
Almaretto's Avatar
Almaretto Almaretto is offline
Super Moderator
Mein Auto: Test Vehicles
Originally Posted by mochoukri View Post
Hi Guys,
when i start the esys launcher pro i get the following error:
E-SYS LAUNCHER ERROR
LOADING E-SYS LAUNCHER PSDZ API MODULE FAILED!
ERROR : C:/PROGRAMDATA/TOKENMASTER/E-SYS LAUNCHER PRO/BIN/PSDZAPI.DLL : CAN'T FIND DEPENDENT LIBRARIES
Anyone knows what this means?
Thanks in advance
Try reinstalling Launcher after first deleting all traces.
Old 08-12-2019, 08:29 PM
choginwat choginwat is offline
Mein Auto: BMW E60
Hi friend,
Can you help us for some things. I found some data sheet about F10 modules So, we canít found some modules.
Example
I want to code module HU_CIC or HU_NBT I not found this but found only HU_CAMP2 and then I want to have sound(beep) when lock/unlock door I canít found F2D module too.
My car is BMW 520d LCI Y2014 with small screen.
Thank
Old 08-13-2019, 01:11 PM
bms5 bms5 is offline
Mein Auto: 335d, X5 35d
Descriptions missing for coding HKFM2
Connected with my old laptop with 3.27.1 and 4.18.22 (canít load Esys on my new laptop because of the date and Token conflict).
I was able to connect and do some FDL coding in BDC using both Cheat Codes as well as manual editing.
However, when I read coding data from HKFM2 CAFD_00005710_004_000_000 and attempt to Edit FDL, there are no descriptions showing up to know what to edit and Cheat Code section is empty. I am trying to code hatch closing with fob and inside button.
I-Step (current) is F-25-18-11-520
Any help is greatly appreciated!
Old 08-13-2019, 02:55 PM
Curamrda's Avatar
Curamrda Curamrda is offline
Mein Auto: Fxx
Cheers
the last working esys + free lauchner is esys version < 3.0 + launcher 2.8.2 - but not recommended for G-series
Old 09-20-2019, 06:53 AM
Fettler Fettler is offline
Mein Auto:
Hi Guys,
Thanks in advance
Hi, I have the same problem as Mochoukri above:
New install of E-Sys v3.27.1 build 44813 with TokenMaster's free E-Sys Launcher Pro v2.82.162.
When I run the launcher I get error message: "Loading: E-Sys Launcher PSdZ API Module Failed! Error C:\ProgramData\TokenMaster\E-Sys Launcher Pro\bin\PSdzAPI.dll: Can't find dependent libraries."
I'm using Windows10 Home laptop.
When I start E-Sys without using the launcher, it runs and connects to my vehicle. I have downloaded PSdZ data and put it in C:/data/PSdZdata and I have re installed E-Sys Launcher.
Did thie problem get solved? Any help would be much appreciated, thanks
Old 09-20-2019, 07:01 AM
shawnsheridan's Avatar
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
Originally Posted by Fettler View Post
...When I start E-Sys without using the launcher, it runs and connects to my vehicle. I have downloaded PSdZ data and put it in C:/data/PSdZdata and I have re installed E-Sys Launcher.
Just to be clear, it goes in c:\data with the result being c:\data\psdzdata. It does not go in c:\data\psdzdata with result being c:\data\psdzdata\psdzdata.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 09-20-2019, 07:13 AM
Mein Auto:
Thanks For your reply Shawn, My path is c:\data\psdzdata and in that psdzdata folder there are 7 folders: extlibs, kiswb, mainseries, mapping, security, swe, temp and 1 file: Version
Old 09-20-2019, 09:38 AM
Then I do not know why your Launcher PRO has PSdzAPI.dll.
Is latest .NET Installed?
Old 09-21-2019, 10:40 AM
joopi joopi is offline
Mein Auto: F30
Hi
I have E-Sys v3.27.1. where can i download the E-Sys Launcher?
sorry for my english.
Old 09-21-2019, 10:48 AM
Originally Posted by joopi View Post
Hi
You can use E-Sys Launcher PRO 2.8.2 for free, at least until April 2020 when it expires:
http://tokenmaster.blogspot.com/2019...r-pro-282.html
Old 09-21-2019, 11:05 AM
Mein Auto: F30
Thank you
and newest psdzdata?
Old 09-21-2019, 11:09 AM
Thank you
What is wrong with links in first post?
Old 09-21-2019, 11:12 AM
Mein Auto: F30
Nothing, the first post ist the launcher and now i am asking for new psdzdata.
Old 09-21-2019, 11:17 AM
Go back and Read Note 2 at Top.
Old 09-21-2019, 11:23 AM
Mein Auto: F30
i am sorry, i didnīt see it.
thank you
Old 09-21-2019, 11:24 AM
thank you
Old 09-24-2019, 11:20 AM
Mein Auto:
[QUOTE=shawnsheridan;13111257]Then I do not know why your Launcher PRO has PSdzAPI.dll.
Is latest .NET Installed?[/QUOTE
Apologies for the delay. Yes, I've got .NET 4.8 installed. I've tried uninstalling and reinstalling E-Sys and E-sys Launcher several times, but still have the same problem with 'PSdZ API Module Failed ESys Launcher Pro\bin\PSdzAPI.dll: Can't find dependent libraries
Old 09-24-2019, 12:05 PM
[QUOTE=Fettler;13114583]
Try running as Administrator.
Old 09-24-2019, 12:08 PM
Mein Auto:
Thanks for your suggestion. I had tried running as administrator, but the problem is the same
Old 09-24-2019, 12:10 PM
Mein Auto:
Thanks for your suggestion. I had tried running as administrator, but the problem remained the same
Old 09-24-2019, 12:19 PM
No idea then. E-Mail Developer TokenMaster at [email protected] and ask him.
Old 09-24-2019, 12:21 PM
Mein Auto:
Thanks for your help, it's driving me nuts
Old 09-28-2019, 11:53 AM
ashu_20m ashu_20m is offline
Mein Auto: 2012 528 xi
my Windows 7 laptop is able to connect to the car with OBD II cable and i get the message connection established after selecting the Target Selector in E-sys
I also see the network icon with yellow exclamation mark as expected
When I connect using my Windows 10 laptop (disabled wi-fi/ bluetooth) I don't see any network icon show up with yellow exclamation mark even after waiting for 5 mins.
In E-sys when I try to connect to car after selecting the target, it says connection failed.
Anybody ran into the issue with Windows 10 laptop not connecting to the car via OBD II cable
PS : I did disable the Norton firewall just in case that was blocking
Esys - 3.33.4
LaunchPro - 3.5.1
v.4.19.30_PSdZData_Lite
2012 BMW 528 xi
Old 09-28-2019, 12:04 PM
Esys - 3.33.4
LaunchPro - 3.5.1
And you Windows Firewall also is not running? Is motor running? Are you using Connect via VIN?
