How can you tell when a rim is BMW Original? - Bimmerfest - BMW Forums
Old 07-17-2011, 01:13 AM
ibrant ibrant is offline
Mein Auto: BMW E39 530i A
I know it is maybe a newbie Q. but I can't tell when a rim is original or not. there are so many replicas that looks almost the same as BMW rims but there not. I encountered a set of rims that looks like the M5 rims of E39 which the writing of "Made in Italy" at the inner side, can it be original rim? I'm expecting it to be "Made in Germany"
I really need to know that key points for identifying.
Thanks!
BMW E39 530i A
2002
Old 07-17-2011, 03:40 AM
Piston_broke's Avatar
Piston_broke Piston_broke is offline
What was that noise??
Mein Auto: E28 M535i, E30 323i
Right off the bat I'd say you'd be best to check on the inside spokes of a rim for the letters BMW and not BWM, which is what I read one time about what reps can have on them.
I smell a rat with the fact they were made in Italy. Better though than if they had come out of Hong Kong, lol.
Following are some pics of the inside of 3 spokes on a genuine (oem) 19" BMW rim (style 132) that I bought for my X5. I gave them a real good clean before I had them fitted and exposed all stamps on the inside.
I imagine e39 rims would be similar (re markings) and to that look for stamps/markings somewhat the same. Hopefully someone will chime in with pics of e39 rims.
GL getting hold of your new rims.
PB
Old 07-17-2011, 08:40 PM
530iman's Avatar
530iman 530iman is offline
03 540i now
Mein Auto: 2003 bmw 540i E39
Some wheels have the numbers on the front circling the inner hub. All OEM wheels have a part number stamoed on them, et and size of wheel. If the wheels you are intending to purchase do not have the long set of numbers like in the pic above they are not OEM wheels. You can Google his part number from the pic and it will show you that it is OEM Equipment.
2003 540i M-Sport custom magnaflow exhaust so far....
Old 07-17-2011, 09:51 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Actually, the rim is only part of the wheel, and then only if it's a 2-piece wheel.
Old 07-17-2011, 09:55 PM
530iman's Avatar
03 540i now
Yeah. ++1.
Old 07-17-2011, 11:51 PM
QSilver7's Avatar
QSilver7 QSilver7 is online now
Mein Auto: 2006 X5 4.4/2013 650ix GC
Ditto what was mentioned above. The wheel will have either all 11 or the last 7 digit BMW part nbr somewhere on them (around the hub or back of spokes)..and will also have the wheel specs & offset info. The offset info will be proceeded by either "IS" or "ET".
style 5 wheel with last 7 digits of part nbr stamped around the hub (circled in red in pic below) along with other wheel specs and the BMW trademark acronyms
style 37 MPar with all 11 part nbr digits stamped on the back of the spokes as well as other wheel spec info and BMW trademark
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 07-18-2011, 05:36 AM
Shires's Avatar
Shires Shires is offline
Mein Auto: E39
My factory fitted style 71 wheels were made by Cromodora in Italy and they say Italy on the back, so it's not outside the bounds of possibility. They do have "BMW" and BMW part numbers stamped on them.
Old 07-18-2011, 09:09 PM
Thanks guys, so I should look for the stamp of BMW and a number so I can google it after to check for genuine OEM, BTW I read here http://www.e39m5.net/style-65-e39-m5-alloy-wheels that at the 65 style rims an Italian company was involved, don't know if it gives the right to stamp "made in Italy".
BMW E39 530i A
2002
Old 04-24-2012, 11:34 PM
Guys, I found my perfect rims!! It's from E65, style 94, 18", Original BBS & BMW, stamped with BBS logo at the inner side of the rims. I think it looks great.
BMW E39 530i A
2002
Old 04-25-2012, 08:02 AM
tmvE39/E53/Z32's Avatar
Mein Auto: Dinan //M5, Dinan 4.8iS,
You need to bore out the hub of the wheel to make them fit.
2000 Dinan S1 //M5 (my DD), 06 DINAN E53 4.8iS (wife's DD), 90 Straman Z32TT (my pride & joy ride)
Gone, but not forgotten: 01 E53 3.0i, 01 525i Sport, 03 DINAN 540i MSport, 01 //M5 and 91 Z32TT
Old 04-25-2012, 08:31 AM
El Goodo's Avatar
El Goodo El Goodo is offline
Mein Auto: 2009 M3 Sedan, Auto
Indeed. That is kind of a pet peeve of mine.
Old 04-25-2012, 08:34 AM
BentValve's Avatar
BentValve BentValve is offline
Mein Auto: 15 328xi
I've seen a few style 65 Reps that are made in Italy....
Old 04-25-2012, 12:38 PM
ECSTuning's Avatar
Instructor of the Stig™
ibrant - If those bolted right on and the hubs seated properly they've either been bored out previously (a good thing) or they are replicas. The E65 has a different center bore than the E39.
ECS Tuning your #1 source for all things German automotive
Customer Service Hours: M - F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
800.924.5172 | OEM BMW Part Number Search
[email protected] | [email protected]
Old 04-25-2012, 10:29 PM
yep... the tire repairman did had to bore them, but i'm upset with his work. the car shivers between 80kph and 105 kph and it ruins its perfect ride. I do need to bore them again in a professional place.
[IMG]
From April 26, 2012
[/IMG]
BMW E39 530i A
2002
Old 07-05-2012, 12:14 AM
E39 Bore measurments
Guys, can you tell me what is the correct bore measurement I should ask my carver to carve?
as well as the current rime bore measurement..
Thanks!
BMW E39 530i A
2002
Old 07-05-2012, 05:10 AM
with BBS stamp on it?
BMW E39 530i A
2002
Old 07-05-2012, 05:18 AM
Thanks!
I Guess I'm answering my self..
atached is the size of the central bore.
Name:	BMW wheel offset_ Hub Chart.jpg
BMW E39 530i A
2002
