X5 35d CEL P205b - Page 4 - Bimmerfest - BMW Forums
Old 01-17-2015, 11:18 AM
lpcapital lpcapital is online now
Send a message via AIM to lpcapital Send a message via MSN to lpcapital Send a message via Yahoo to lpcapital
Mein Auto: Wasp & Duc
Originally Posted by PIXLFIX View Post
Interesting that one if the outlets doesn't have any hose on. Just a lot of crystallized urea.
Attachment 487085
I'm just taking taking a guess here since I've not seen that unit in person, but the outlet may be #5 at page 144 of this paper: https://drive.google.com/file/d/0B1e...ew?usp=sharing
It's labeled "operating vent" and has to do with the urea heating system.
Old 01-17-2015, 01:02 PM
PIXLFIX PIXLFIX is online now
Mein Auto: E70
Ok, disassembled the old tank.
Unfortunately the crystallization theory is wrong. Didn't find any crystallization inside the tank.
And this is the culprit. Visually nothing wrong with it.
Old 01-17-2015, 01:23 PM
Mein Auto: E70
However...... May be this is what's causing the issue. Barely visible residuals on the contacts.
Old 01-17-2015, 01:39 PM
Mein Auto: E70
Probably not though.
There is a base contact (nr1) and 3 other contacts. On the good sensor there should be the resistance between nr 1 and other pins (2,3 or4) 10kOhm (when the tank is empty). And yes, my new tank have this resistance.
On my old tank there is no contact at all on this connector - infinite resistance.
Old 01-17-2015, 01:41 PM
So is it the reference pin damaged?
Old 01-17-2015, 02:09 PM
Mein Auto: E70
No, the pins are fine. Just no resistance.
In overall:
There are 4 metal contacts on the sensor. Connected to the corresponding contacts in the connector. There is a 0ohm connection between the metal contact on the sensor and contact in the connector. Which is good.
Per Rheingold there should be 10kOhm between the first contact and any of the other contacts. Old sensor doesn't have this resistance for some reason. May be there is some kind of circuit inside the sensor (not visible) which is not working properly.
Interesting, that this sensor is being advertized as non replaceable, but it's definitely is.
Old 01-17-2015, 04:06 PM
Interesting! The 10kOhm is likely how the sensor is diagnosed.
If 10k Ohm is measured then the pin is not covered by Urea, if the circuit is open then the sensor is damaged. When the sensor is covered by Urea the resistance is very low.
If that's the case than the sensor may be fixed by adding a 10k Ohm resistor from Radio Shack between the base pin and all others.
If my theory is right, try submerge the sensor is urea, expose the different prongs and measure resistance. If you get a low value than the sensor itself works...
Old 01-17-2015, 05:40 PM
Mein Auto: E70
Sure thing. Because all those metal contacts on the sensor are hardwired to the pins.
And of course if you measure the resistance between 2 and 3 or 2 and 4 or 3 and 4 you are getting around 19-20kOhms.
I'm just curious, what may happen to all those resistors inside the sensor. Were the fluid get inside and they've corroded or something?
This sensor on the pictures above is also the temperature sensor. So in overall there are 6 wires are coming out from it. 4 for the level sensor and 2 for the temperature sensor.
Old 01-18-2015, 11:38 AM
ninja_zx11 ninja_zx11 is offline
Mein Auto: 2009 X5 35D
So have you finished putting back the new part?did it resolve the check engine light issue?
Old 01-18-2015, 01:19 PM
Mein Auto: E70
I believe I'll will go with the old part just adding the dummy circuit shown above. I'm pretty sure it will solve the problem. After the success confirmation I'll put the new tank for sale ))
Old 01-18-2015, 03:21 PM
Mein Auto: E70
Work in progress
Old 01-18-2015, 04:05 PM
Mein Auto: E70
Done ))
Old 01-18-2015, 06:30 PM
ard ard is offline
Resident Curmudgeon
I was going to say, the color code wasnt maintained...glad you shrink wrapped that!
Alignment here: The Definitive Alignment Thread
OE is Original Equipment aka 'BMW Original Parts' aka 'What you buy at the BMW dealer with a BMW label'
OEM is Original Equipment Manufacturer... EITHER the company that made the OE part or.... A part this is identical to the OE part, but is sold by the OEM under their own label
OEM is not what BMW sells
http://www.bimmerzone.com/category/T...ricks_OEM.html
https://www.turnermotorsport.com/t-OEvsOEM
Old 01-18-2015, 07:07 PM
Mein Auto: E70
X5 35d CEL P205b
I wasn't concerned about color coding, because those white connectors are fail-safe and it is impossible to plug in this dummy-insert in any other position than correct one (vise versa or upside down).
Test driving right now. No any issues yet.
Old 01-18-2015, 08:39 PM
Old 01-18-2015, 09:28 PM
Mein Auto: E70
I'm still trying to figure out how come it helped last time to rinse the tank with the water? There wasn't absolutely no any crystallization inside the tank. The only idea coming is that I was using the warm/hot water which made a temperature shock to the sensor restoring the failing contact inside. Can't figure out anything else.
Now, I'll drive ~200-300 miles and if everything will be fine - I'll put the new tank for sale.
Old 01-18-2015, 10:54 PM
Nice job!!!!
Old 01-18-2015, 11:28 PM
henrycyao henrycyao is offline
Mein Auto: BMW X5 35d
I understand the sensor is not important. This looks more like by passing the sensor rather than fixing it? A true fix would require testing the near empty condition and see if you trip the sensor. Am I wrong?
2012 BMW X5 Vermilion Red Xdrive35d with Premium Package, 3rd Row Seats, and Adaptive Drive
Old 01-19-2015, 05:46 AM
Mein Auto: E70
All sensing data is still working fine. It wasn't passing "self-check" only. Now it's does.
Old 01-19-2015, 09:14 AM
smyles smyles is offline
Mein Auto: X5
Is there any identification on the sensor itself, to search/source it?
Old 01-19-2015, 09:47 AM
Mein Auto: E70
There is completely nothing. Just half distorted looking kinda QR code.
Name:	def sensor 4.JPG
Old 01-19-2015, 12:55 PM
ard ard is offline
Resident Curmudgeon
A few comments:
the color code thing was a joke.
the actual sensor may be buried.
I have no idea what kind of sensor BMW uses...
http://www.meas-spec.com/downloads/S...ty_Sensors.pdf
Old 01-19-2015, 01:13 PM
Mein Auto: E70
The temperature sensor is buried (it's located inside the level sensor). Level sensor contacts are exposed as it is visible from the pictures. The only thing which is buried for the level sensor is self-check circuit.
Old 01-19-2015, 08:00 PM
You did a terrific job with this project!!! Thanks very much.
I'll add this to our DIY section for future reference.
Old 01-19-2015, 08:23 PM
Mein Auto: E70
Sounds good. I'll provide with the progress if there will be any other issues.
