M62TU vanos solinoid check valve - Bimmerfest - BMW Forums
Old 07-01-2015, 09:40 AM
mrblahh mrblahh is offline
Mein Auto: X5D, 135i, 540i, r53 *2
I need to replace my vanos solenoid check valves, anyone have a DIY? Did not see one in the bestlinks
Old 07-01-2015, 12:45 PM
ca2014mp2 ca2014mp2 is offline
Mein Auto: E39 2000 528ITA
Well, I know there is a piston, oring.. spring and solenoid. Haven't noticed a check valve but if you are looking just to replace the solenoids the dyi are here. you just unscrew them. very simple .. just like a spark plug..
Series E39 Vehicle code DP63 Model 528ITA Engine M52TU
Body type OTHER Catalog model USA Production date 1999 / 06
Transmission Automatic Steering Left Catalyzer YES
Production FROM : 1998/09/01 TO : 1999/08/31
Old 07-01-2015, 12:55 PM
The check valve is buried inside past the solenoid, part number is 11121706921 I think
Old 07-01-2015, 01:16 PM
I didn't want to say anything because the OP mentioned they looked in the bestlinks, which is the only place I looked.
Therefore, the OP already knows of the Besian DIY (pictured below).
So, what I need to ask then is what's exactly is it you find MISSING in the check-valve removal procedure in the Besian DIY?
Here is just one tiny snippet of that well-known DIY...
ID:	517259   Click image for larger version
ID:	517261   Click image for larger version
Old 07-01-2015, 02:58 PM
I said I searched, did not find it and no you are not hurting my feelings posting info, I did not look at the vanos procedure obviously or I would have seen they mention the check valves
I did find an X5 howto on another forum that has step by step that I needed, no where near as involved as removing a vanos for seals
Old 07-01-2015, 03:06 PM
Clever, Clever BB... Hey, isn't your usual pattern to say something on the order of ... I typed /x and then F3 and found?.... I do have one more question, I'm curious, how do you quantify 'well known'? It's not too often that I've seen a thread ask this question in fact I can't recall when was the last time this questions was asked. Thanks in advance..
Old 07-01-2015, 07:17 PM
That explains my confusion because vanos and besian are almost synonymous on this forum, so, I figured you had to have already looked at it.
BTW, I've never done my VAnOS, and I only skimmed the Besian (because I knew if it was important, it would be there), so pardon my dumb question.
But, is it as simple as you screw in a threaded rod, and then you just pull the thing out with backward force?
Would you kindly provide a reference so that I can make this thread here (i.e., your thread) the canonical thread in the bestlinks on how to remove the VANOS solenoid check valve?
- How to remove the VANOS solenoid check valve (x)
(Where x will be this thread.)
That way the next person with the same question stands on your shoulders.
I don't see anything clever in what I wrote.
A question was asked, and all I did was look up the question.
Since I found that answer in the same spot anyone would look, I had wondered if the procedure was missing a step or three (it happens).
Nothing clever whatsoever.
Let me tell you my M.O. for most threads:
a) I skim them (if it takes me more than about five seconds to skim the entire thread, that's too long).
b) I decide what the basic question is talking about
c) I type the keywords and provide the link
d) I move on to the next thread.
Since I skim threads, I can easily get the specific question wrong; but, I generally have the general topic figured out in those few seconds.
In most cases (99% of the time lately), the answer to the question has been well documented (as it appears to have been in this case), so, my MO should work if the person clicks on the links.
In this specific case, I had known (from the way the OP was written) that the OP had already said they had clicked on the links, so, I clicked on them myself, to see why they hadn't answered their question.
When I saw the answer as plain as day, I questioned my assessment of the problem set (which sometimes I get wrong).
I think you skimmed my answer!
I never said, nor even implied, that the specific question of how to remove the VANOS oil pressure check valve was a well known question.
What I said was that the Besian DIY is pretty much the universal standard for VANOS, so, I knew that anything worth asking about for VANOS removal procedures would be in that DIY.
Again, when the OP intimated that it was not in that DIY (by implying he had checked all the links in the bestlinks that referred to VANOS), I simply LOOKED at the DIY (took me another ten seconds).
When I saw it, I was perplexed, so I asked the OP what was missing from the procedure (since I was sure the OP had seen it since it's the procedure EVERYONE goes to).
Anyway, the answer is simpler than I had thought.
To move forward, I ask the OP to snap a picture or two of the procedure, and we'll make THIS THREAD the canonical thread, so that when someone types in /check valve f3, they'll find this thread in the future.
Old 07-02-2015, 05:05 AM
I would not call this well known as I searched a lot on rattles and find a thousand links to the cam chain tensioner but not this check valve & vanos rattle, I Found the x5 and some landrover info before posting here figuring there was probably an e39 howto somewhere but I have not found one yet, the besian instructions are very different and for a full vanos rebuild, I'm definitely not doing that as my vanos works fine. I have done vanos seals before and will never do one again unless it absolutely requires it.
http://www.xoutpost.com/bmw-sav-foru...ck-valves.html
looks pretty easy
Old 07-02-2015, 11:53 AM
We're still misunderstanding each other, but, let's drop that discussion, as it's not important what we thought.
What's important is HOW to do the job.
Moving forward, thank you very much for that explicit reference:
M62 Vanos Seals and check valves
My X5 started to get a slow leak of oil from each of the Vanos seals. So I replaced the seals and also changed the check valves that are behind the solenoids.
I didn't use the BMW special tool that was mentioned in the Bentley manual. I used some plumbers wrenches that fit the solenoid. I also used a bolt to thread into the check valve and pull it out.
The passengers side was easy. The drivers side involved draining the coolant and removing the water pump - radiator hose assembly.
Took 3 hours taking my time and cleaning things as I went.
What matters is that this thread is now a canonical thread in the bestlinks, so that someone who searches /keyword should find it.
I always try to put keywords into the reference that others would use (even purposefully mis-spelling them, if that's what people use), but I'm not sure what keywords they'd use for this DIY.
And I noticed that the part is listed on the tag in the picture below as a "non-return valve", so, given these keywords ...
How does this proposed bestlinks reference look so that you would have found it, had it existed?
- How to remove the vanos oil pressure solenoid check valve non-return valve (1)
BTW, I wasn't sure exactly what BOLT SIZE to use (thread + pitch + width).
Do you have that bolt size so that the next person starts with the correct size.
Old 07-02-2015, 12:04 PM
M10 x 1 but I think m10 x 1.5 threads on enough to get the valve out
I am only replacing the o rings on mine
Old 07-02-2015, 01:23 PM
Thanks for confirming the bolt size, as this canonical thread will help others gather the right tools ahead of time, so it's good that you tell us whatever you can while it's in front of you.
BTW, while it's fresh on your mind, what is the size of the check-valve o-rings?
Note: We would want to add the o-ring size you report to this thread so that others can order it, in advance, during routine parts ordering:
> E39 (1997 - 2003) > Complete list of all o-rings (by size & by part number) to buy when ordering parts
Old 07-02-2015, 01:32 PM
heck if I know, I have a box of various sizes, when I remove mine I will find one that fits
Old 07-02-2015, 01:36 PM
Generally what is needed is the ID and OD, or the OD and the cross section, usually in millimeters.
I usually measure mine with a mic, but even a caliper would work.
Old 07-27-2015, 06:59 AM
Pass side done, the O ring was intact but visibly worn, new viton o-ring in place noticeably snugger. My 32mm socket would not fit into drivers side, gonna try the showerhead socket set tonight
I hope this fixes startup rattle in the vanos but I do not have a lot of faith that it will
Old 07-30-2015, 02:40 PM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
FTW Trump 2020!
Mein Auto: 2001 540i/6
i still haven't figured out if BB is a low level A.I. or an actual human.
Wordings he uses, most peculiar they are.
Schmiedman M5 headers
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 07-30-2015, 03:11 PM
bobdmac bobdmac is offline
Older than old school
Mein Auto: 01 540i/6, k75s, 86 Westy
In my experience, "startup rattle" differs from "VANOS rattle," at least for my M62TU V-8. The VANOS noise persisted indefinitely with the car at idle, especially with the car fully warmed up.
Old 07-30-2015, 04:14 PM
the rattle I have at startup is inside the vanos, I can feel it with my hands
It did cure most of it, every once and a while I still get one, and only if the car sits for a few hours so whatever is draining has time to drain. I do not think it's the oil filter as it's got oil in it when I check, but it could be the check valve in there too
Old 07-30-2015, 04:30 PM
I went back and read your earlier post, which I had overlooked, and saw you had replaced the VANOS seals, which would explain why the noise occurred only at startup. Interesting fix. I'm glad I replaced the check valves when I did the VANOS.
Old 07-30-2015, 04:33 PM
I have not replaced my vanos seals
Old 07-30-2015, 04:39 PM
I'm definitely not doing that as my vanos works fine. I have done vanos seals before and will never do one again unless it absolutely requires it.[
Okay, I got confused. I thought in this sentence you were referring to the car that had the startup noise.
Old 07-31-2015, 09:57 AM
SSJRICH 540i's Avatar
SSJRICH 540i SSJRICH 540i is offline
2000 M5
Mein Auto: '00 M5
"he"....... ooooooooooooooo
Current - '00 M5 - '02 530i M sport - '02 X5 4.4i Sport - Old - 00 540i/6 M sport -Old - 97 540i/6
