Hifi Audio upgrade project - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > F12 / F13 (2012 - 2018)
The all new 3rd generation 6 series coupe (F13) and convertible (F12) forum. The F06 BMW 6 Series Gran Coupe forum is here
Old 06-27-2016, 03:11 PM
EuphoricGrIn EuphoricGrIn is offline
Mein Auto: 640d MSport Coupe
I have owned my 2012 640d MSport Coupe for 3 months now... and from day one I was disappointing with the "BMW 676 Hifi" sound system. I previously owned a 2004 545i with Logic7 and my wife drives a 2008 X5 4.8i, also with Logic 7. I'd have been happy with a system that matched either of those... but the system fell well short.
I decided I needed to upgrade (I plan to own this car for 5 years, and want to enjoy it to the fullest extent possible). After weeks of research I decided upon a course of action - with the following goals in mind:
  1. No damage to the vehicle. No cutting wires or making holes. No breaking clips and studs.
  2. Complete "stealth" - ideally, not even BMW would know (unless they turned the volume up... or did some digging)
  3. No impact on Motorplan (I hope)
  4. Best bang for the buck... and I live in South Africa, so getting stuff here is inevitably expensive
  5. DIY... I didn't want anyone damaging my new baby
The plan
Because I wanted to keep the vehicle looking 100% stock and did't want cut into any of the vehicle's wiring, I purchased a custom harness that will allow me to unplug the factory amp and replace it with new amp(s) without cutting into the vehicle's wiring. The 2 options were:
1. TechnicsPNP
2. eBay
I went with the Technics option - he's been active on the forums for years and the harness gets lots of great reviews. I'm glad I went this route - it really made the install much easier!
The harness allows me to:
  1. Route the signal from the headunit to a replacement amp by plugging the analogue RCA plugs from the harness into any amp supporting balanced differential inputs (very important!)
  2. Route the outputs of the amp(s) via the OEM wiring to the various existing speaker locations (where I'd be able to install better subs/woofers/tweeters and plug these directly into the existing wiring)
The components I have purchased (and mostly installed):
1 x Rainbow IL-C4.2 F (part 231247) - pair of mids & tweeters for the front doors
2 x Earthquake Sound SWS-8X 8-inch (2 Ohm) Shallow Woofer System - under each of the front seats
2 x Earthquake Sound R8SWS Installation Ring Adapter for Speakers
2 x Kicker 12CX3001 CX-Series Monoblock Power Amplifier - [email protected] Ohm;, [email protected] Ohm;
1 x 4 channel Alpine MRV-F300 - 50Wrmsx4 @4 Ohm;, 75Wrmsx4 @2 Ohm;
I routed the Left and Right balanced differential signals to each of the Kicker amps, and took the line level outputs from the Kicker amps to the Alpine. The Kickers each drive a SWS-8X underseat sub and the Alpine will drive the Rainbow IL-C4.2 F's in the front doors, as well as whatever speakers I put into the rear (window shelf and/or sides).
I completed the install this weekend and there's a dramatic improvement in quality and power. I have dropped from the oem 7 channels to 6, so have sacrificed the the front centre speaker, but the telephony and navigation still work fine. The reason I went with the Kicker amps is simply because they're relatively inexpensive, compact, have good reviews, and accept the balanced differential signal generated by the BMW 676 Hifi headunit. I could have purchased just one Kicker amp, and used it to drive the 2x 2 Ohm; subs in series, but then I'd only have access to 2 channels from the head unit instead of 4 (which would effectively mean the fader wouldn't work anymore). It seems that I could either use Rainbow IL-C4.2 (2 way) or the Rainbow IL-X4 F (co-axial) speakers in the rear - or just leave the rear's OEM for now (I'm still undecided).
Below are some photos - I hope it'll inspire / help one of you guys. I didn't take photos of the underseat subwoofer installation process because it's pretty similar to the process for other BMW models (which is well documented online) - it involves removing a couple of bolts, folding the seat and the leaning it back. I didn't need to remove the plastic sub enclosures, but do recommend the installation ring adapters - they form a tights seal with the subs which I've read is critical.
The original (feeble) 7 channel "Hifi 676" OEM amp:
Here's the space once the OEM amp and bracket are removed (the harness I purchased from Technics is in the foreground - well worth it - makes the install plug 'n play). I did need to make 3 "non-reversable" changes to maximise the space available - I cut off 3 of the protruding bolts that are used to fix the OEM amp bracket in place.
The three amps that need to fit in that tiny space...
The 2 Kicker Monoblocs are really tight squeeze (they're mounted on a thin board, with foam rubber underneath). I had to solder custom 90 degree RCA plugs... straight plugs wouldn't fit. I was a little concerned about heat build up, but the gain on both of the Kickers is turned all the way down (the underseat subs are rated at "only" 150W peak), and they're very efficient class D amps - so far, no issues.
Everything (miraculously) fits:
All back together... and it all works!
Last edited by EuphoricGrIn; 06-29-2016 at 03:41 PM. Reason: Pics not visible to all fixed (I hope!)
Old 06-28-2016, 09:47 PM
Tmyz Tmyz is offline
Mein Auto:
And the cost was?
Old 06-29-2016, 02:35 PM
amanra's Avatar
amanra amanra is offline
Mein Auto: 2012 BMW 650i
This looks amazing I've been considering some level of upgrade and have found the midrang and highs to be sufficient but wanted a better lowmids and subwoofer range
With your complete change up how do you feel the sound ranks now
Old 06-29-2016, 03:57 PM
@Amanra: Massive improvement in the low range - the Earthquake subs are night and day compared to the stock units (I installed them first, and even on the stock amp they sounded much better - now they really thump). They're rated at 150W max, and the Kicker amps are 300WRMS into 2Ohms... which is clearly overkill and will doubtless do damage if I turn the gain up. I haven't installed the Rainbow splits and back speakers yet... will let you guys know over the weekend how that works out.
@Tmyz: Costs were:
1 x Rainbow IL-C4.2 F (part 231247) - pair of mids & tweeters for the front doors - cost about $320 in South Africa
1 x Rainbow IL-X4 E - speakers for rear sides - $160 in South Africa
2 x Earthquake Sound SWS-8X 8-inch (2 Ohm) Shallow Woofer System - under each of the front seats - $90 each on Amazon warehouse deals
2 x Earthquake Sound R8SWS Installation Ring Adapter for Speakers - $20 on Amazon
2 x Kicker 12CX3001 CX-Series Monoblock Power Amplifier - [email protected] Ohm;, [email protected] Ohm; - also $90 each on Amazon warehouse deals
1 x 4 channel Alpine MRV-F300 - 50Wrmsx4 @4 Ohm;, 75Wrmsx4 @2 Ohm; - $100 on Amazon (a while back)
1 x TechnicsPnP harness for BMW 676 hifi system - $75
+ cabling, fuse box, RCA plugs, etc... - $50
= about $1085 in total.
In addition to these costs I also needed to get everything "aggregated" in the US before having it trans-shipped to South Africa. I use a company called Shipito.com (they're great!). So on top of the $1085, I also incurred repacking fees, shipping costs, import duties and VAT. For context, at the time my vehicle was originally sold in SA, I believe the Harmon Kardon system was approximately a $1000 upgrade. From what I've read, this should sound better (no DSP, but more power and mostly superior components).
Amanra, you could skip the Rainbow speaker upgrade and the cost will have almost halved...
Old 07-07-2016, 04:11 PM
amanra's Avatar
Thanks dude this is a great write up and the overall implementation is solid
Great job!!!
Old 07-28-2016, 11:49 PM
Banzairacer Banzairacer is offline
Mein Auto: 2012 650Xi M package
yes great job on the install and details. Has anyone had any experience with the Focal or know if Focal makes an underseat subwoofer for the 6?
Needed a bit of punch and the local shops here are recommending either an 8 or a 10 with a skibag pass though location - I like the idea. - any thoughts?.
Old 08-21-2016, 12:58 PM
Curamrda's Avatar
Curamrda Curamrda is offline
Mein Auto: Fxx
Hi,
thanks for nice thread. I am going to buy F13 after Christmass, and I am afraid I will not get B&O sound. So I will have to upgrade the speakers and AMP aswell.
I am little bit curious... could you please provide more detailed wiring schema? Isnt to much to one kicker for one sub speaker? Dont you have affraid you will blow it up?
Coz I didt similiar upraged in my E92 with origin hifi audio setup. Changed the speakers and AMP for JL Audio XD600/6 (which has also balanced inputs) , and I have blown 2 times my speakers bellow seat
but I guess the upgrade will be similiar to ugrade e9x 676 hifi audio setup:
http://www.e90post.com/forums/showthread.php?t=641323
Old 08-22-2016, 11:37 AM
BeemerGuy's Avatar
BeemerGuy BeemerGuy is offline
former motorcycle rider
Mein Auto: F87 & F01
Hey Euphoric, thanks for the post! I like how you did everything stealth, that's how I'd want to do it. I am surprised that there are no heat issues with all of those amps crammed into that little space, but maybe 21st century technology has solved some of those issues.
F87 (mine)
E90 (hers)
F01 (ours)
