2014 X1 Won't start - Bimmerfest - BMW Forums
Old 03-16-2020, 09:54 AM
asudhak asudhak is offline
Mein Auto:
2014 X1 Won't start
This morning, I got in my car, pressed the start button, everything flickers and goes dead. No crank, nothing. Later on, I get a bunch of warnings such as ABS failure, passenger restraint failure, and then the alarm goes off.
After a while it seemed to reset by itself, and I was able to unlock the car as though everything was fine. But when I tried to start again, same thing - Flickers on the dash, lights go off, done.
Is this a simple battery issue or something else? What steps can I take to debug.
Old 03-16-2020, 11:10 AM
luigi524td luigi524td is offline
Mein Auto: '17 540xDrive; '98 Z3 2.8
DEAD BATTERY - Door locks require very little "juice" to operate ... Not so the rest of the car!
Search the forum ... tons of posts.
My opinions are free - you'll get exactly what you pay for!
Current: '17 540 xDrive | '13 X1 MSport | '98 Z3 2.8
Past: '13 535xDrive|'07 530xi|'01 740i|'98 740i|'94 740i |'86 524TD
"Seek and ye shall find" - start with your owner's manual!
SPAM links removed. Not permitted on Bimmerfest
Old 03-16-2020, 01:44 PM
Yukoner Yukoner is online now
Mein Auto: 2011 328i x-drive
Without actually testing, it sure sounds like battery failure to me.
With the vehicle OFF, BEFORE trying to turn it on or crank it, take a multi-meter to the battery. What does it show for voltage ?
Not even sure if -40 degrees is cold anymore ?
Old 03-16-2020, 03:49 PM
Mein Auto:
I used the 'hidden' menu feature and the voltage shows 12.2 when off, and around 14.8 with the car on. I don't have a multi-meter, so I used this technique
Old 03-16-2020, 09:00 PM
Chicone Chicone is offline
Mein Auto: 2015 X1 35i X Drive
A 2014 car would have been manufactured in 2013, seven years on the same battery. Iíve heard of AGM batteries going longer, but you are probably due. If you have access to a AGM compatible charger, hook it up overnight and see if it helps.
Steve
2015 BMW X1 35i MSport
Old 03-17-2020, 10:20 AM
Mein Auto:
Ok, the dealer quoted me $260 for the AGM battery, so I think i'm going to go with that.
For battery registration using INPA, I don't see E84, so can I use N20 engine option under the F30 menu ? I couldn't find any threads on this on the forum.
Old 03-21-2020, 07:37 AM
JimH46 JimH46 is offline
Mein Auto: 2014 X1 xDrive28i
That not a bad price for a battery from the dealer. An AGM of the right size is going to be about $200 just about anywhere else. If the dealer puts it in, I would think they would also "register" it with your car's computer.
Old 03-21-2020, 08:09 AM
Mein Auto:
Oh no, $260 was only for the part from the dealers part dept not installation
Old 03-24-2020, 05:33 PM
richsantana174 richsantana174 is offline
Mein Auto: 2015 X1 28x
I got a AGM battery at Advance for my 2015 X1 XDrive28I. Installed it and bought a reader through Amazon. Registered the battery with no issues.
I believe they are 2 sizes and I went with the bigger battery. I ended up paying $154.
