2014 X1 PDC Malfunction - Bimmerfest - BMW Forums
Old 05-11-2020, 11:24 AM
Lavapit315 Lavapit315 is offline
Mein Auto:
Hoping someone can help me out. I am receiving PDC alert when shifting into reverse. I just stopped by a shop and they hooked up a code reader and it has the following errors.
Terminal 30 Power Supply Switched Off (Anything to worry about? Would it have anything to do with below errors)
9E38 Wire Ultasonic Sensor Front Right (2 sensors failed or not likely)
9E2F Wire Ultasonic Sensor Front Left (2 sensors failed or not likely)
Could anyone please help me out? Any guidance would be greatly appreciated.
Thank you
Old 05-11-2020, 12:03 PM
Yukoner Yukoner is online now
Mein Auto: 2011 328i x-drive
Does your PDC work ?
Not even sure if -40 degrees is cold anymore ?
Old 05-11-2020, 03:31 PM
Mein Auto:
No, I don't get the beeps if I'm close to any objects. Backup camera works.
2014, bmw, x1
