Compressor - Bimmerfest - BMW Forums
Old 05-23-2020, 12:55 PM
cbs2669 cbs2669 is offline
Mein Auto:
Compressor
How difficult is it to replace the compressor in a 2013 X1? I can't find any tutorials anywhere. I hate to shell out money to a service shop if I can do the work myself.
Old 05-23-2020, 12:59 PM
Doug Huffman's Avatar
Nuclear engineer
Originally Posted by cbs2669 View Post
How difficult is it to replace the compressor in a 2013 X1? I can't find any tutorials anywhere. I hate to shell out money to a service shop if I can do the work myself. Thanks
Why do you think that your compressor (HVAC IHKA I presume) needs replacement. That is HIGHLY unlikely.
Look on NewTIS.info. The prerequisites and precautions before and after are significant.
https://www.newtis.info/tisv2/a/en/e...ressor/OdJLyjd
https://www.newtis.info/tisv2/a/en/e...essor/8Ht9oKwq
Air conditioning performance check
https://www.newtis.info/tisv2/a/en/e...check/GbGkqA9N
Old 05-23-2020, 02:31 PM
Mein Auto:
Well, the clutch isn't engaging. I think the clutch is bad, but I was told you can't just replace the clutch.
Old 05-23-2020, 02:45 PM
Nuclear engineer
Are you sure that you have a clutch and not a swash-plate regulated compressor? Precisely what E84 have you, what engine? Many / most late model BMW have regulated compressors.
That's what the last line of the performance check is about, that 'gages' won't work to troubleshoot a regulated BMW AC system.
Old 05-23-2020, 03:17 PM
BabyUnicornTaco BabyUnicornTaco is online now
Mein Auto: 2008 X5 4.8i E70 Sport
First check realoem.com and see what compressors were offered for your specific X1. Then you will have part numbers and can find out which type you have. I just went through this with my X5 to figure out if mine was clutchless or not. Newtis.info will have replacement steps.
Sent from my iPhone using Bimmerfest
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 05-23-2020, 04:33 PM
Mein Auto:
Appears I have a magnetic clutch. R134A
