E39 540i - INDIVIDUAL FINE WOOD TRIM - How do I find out what color is mine? - Bimmerfest - BMW Forums
Old 10-02-2006, 07:41 AM
Bradleyjs Bradleyjs is offline
Mein Auto: 2019 F90 M5|2006 E60 550i
PAPPEL NATUR
EIBE CLUB
PLATANE
BIRKE ANTHRAZIT
BIRKE BLAU
BIRKE GELB
OLIV
ARIZONA SUN
ENGLISCHROT
Need to purchase a new: WOODEN COVER F RADIO FLAP
Old 10-02-2006, 08:19 AM
OlyVR OlyVR is offline
Mein Auto:
Take the one above the glove box off. If you look on the backside you should see a sticker with the color name.
FYI, there are four attachment points to this thing - nothing screwed, just pushed in. Starting from the center the first one is about 2 inches from the left edge. Get a nylon interior trim tool, or something similar and slide it under the trim from the bottom to pry it off. Once you have the first one, it's easy to get the others.
Old 10-02-2006, 12:25 PM
Thank you - that's very helpful.
Old 10-02-2006, 02:48 PM
Psi 5 Psi 5 is offline
Mein Auto: 2007 E90 335
Originally Posted by Bradleyjs View Post
PAPPEL NATUR
EIBE CLUB
PLATANE
BIRKE ANTHRAZIT
BIRKE BLAU
BIRKE GELB
OLIV
ARIZONA SUN
ENGLISCHROT
Just a quick warning though - BMW re-uses part numbers for its interior trim (including shift knobs) depending on the model year. For example, on my 1998 540, a particular part number was printed on the trim piece and the color was "X." Reordering the exact same part number from the dealer now gets a trim piece with color "Y." Same p/n, different trim color. The metalic/titantium ones vary substantially year to year. The wood ones do too although not as much. You may have to order 2-3 to get a close match. I gave up and ended up getting an entire trim set (used on e-bay, not new from dealer) rather than trying to replace one piece at a time. Good luck.
Psi 5
Old 10-04-2006, 12:36 PM
Psi 5
Thank you, when I "pop-it-off" I guess I'll know. BTW: How much was the whole trim set (ballpark figure)? I will eventually need it here with he FL sunshine. :-))
Old 10-05-2006, 04:57 PM
Lscman Lscman is offline
Mein Auto: 540i 6spd
It is foolish to buy the whole trim set. These cars are plentiful in salvage yards and these parts go for about 10% of list price. Several good carbon fiber shops will refinish your interior trim with premium carbon fiber in the shade of your choice for less than 1/2 the cost of new. Scratches, chips and cracks are fixed for free before applying the carbon. It really makes these cars look sporty.
Old 10-05-2006, 05:30 PM
Redshift Redshift is offline
Fibrenew Guy in Raleigh
Mein Auto: X5D x 2, M3T
Another tip - be careful pulling that piece off. You may try a smaller piece instead. When pulling mine off, it cracked in a few places and I had to replace it. It appears that the newer pieces are more reinforced where the metal backing is (the piece is mostly metal and only a small sliver of wood). Take your time and be careful.
Brian
2012 X5D Stage 4
2011 X5D Stage 3
2003 M3 Touring/Wagon
Sold:
2003 M5 Touring/Wagon
2002 330Cic
2001 M5
1994 Euro M3 Track Car
Died:
1995 M3 Coupe
Old 10-06-2006, 02:24 AM
bagmanindy bagmanindy is offline
Mein Auto: 97 528i, 85 318i, landcru
interior trim
I am considering having my trim done up with carbon fiber, can you recommend a good shop?
Old 10-06-2006, 07:49 AM
Does the carbon fiber look the same? Pictures?
The junkyard idea is probably the better idea - I agree. Now I just have to go find one...
Old 10-06-2006, 11:31 AM
eschnabs eschnabs is offline
Mein Auto: 2003 530i
I replaced my whole set for about 750. I ordered from Vaheh at Crevier, but he is no longer there. The wood in 540's is typically called Nussbaum (Walnut).
Old 10-07-2006, 11:41 AM
Believe you're right - thanks!
Similar Threads
This Is The Official Hijack Thread... Sabrina Off-Topic 146 05-21-2009 06:38 PM
t Nick T. The Test Board 5 07-05-2003 09:25 AM
