Steering Wheel won't come down automatically any more - Bimmerfest - BMW Forums
Old 11-11-2007, 10:54 AM
Bradleyjs Bradleyjs is offline
Mein Auto: 2019 F90 M5|2006 E60 550i
It goes in the "up" position when I turn off the car but when I start the car up again I have to manually lower it.
Anybody got a clue? I have seen this behavior before (long time ago 4 years or so) when the battery started going bad. The battery is "green" .....
Old 11-11-2007, 11:32 AM
cn90 cn90 is offline
Here you go
I have the exact same problem so I just adjust the SW manually using the lever when the module "forgets" to do so.
I posted the message here and you can view the responses, especially by Jim Cash:
http://bimmerboard.com/forums/posts/331833/
Hope this clears the confusion.
Old 11-11-2007, 02:37 PM
pauleeee pauleeee is offline
Mein Auto: 98 540i
Sounds like you've lost your memory setting for the wheel. Here's what I do:
Move the steering wheel down well past where you normally like it. Creep it up until
you get it exactlywhere you want it. Then set the memory on the door switches. Works
pretty good.............if that's all the problem is.
Old 11-11-2007, 03:31 PM
chivas's Avatar
chivas chivas is offline
You Lick It, You Own It
Send a message via ICQ to chivas Send a message via AIM to chivas
Mein Auto: 98 540i/6
i had the same problem and it was due to a weak battery.
americandan.com
It takes a lot of work to be lazy.
Old 11-11-2007, 04:26 PM
jsayreshepherd jsayreshepherd is offline
Mein Auto: e39 touring, e46 ZHP
Same here - the problem was intermittant at first, then regular and went away when I replaced the battery. From your post it sounds like you replaced the battery four years ago, so maybe its time?
Old 11-11-2007, 04:28 PM
chivas's Avatar
you know what's really strange about my steering wheel? it USE to not only go up but in when i took the key out. now, it only goes up and down. ?
americandan.com
Old 11-11-2007, 06:12 PM
This makes driving the E39 a 'fun' experience...The Ultimate Driving Machine.....haha.....
Old 11-11-2007, 06:27 PM
Waveho Waveho is offline
Mein Auto: '07 335xi 6MT 4door
Maybe you just need to reset your seat position memory, which also of course controls the steering wheel position and side mirrors?
'07 335xi 6-spd 4dr, Montego blue
'98 540i 6-spd Sport, Jet Black II(sold)
'92 325i 5-spd 4dr, burgundy(sold)
Old 11-11-2007, 06:36 PM
CSMBlack-540i CSMBlack-540i is offline
Search, Read, THEN Ask
Mein Auto: CDN 98 540i M62 3.15
Is it only the steering wheel that has issues? Radio works? Seat works? Could possibly be the ignition switch issue?
Old 11-14-2007, 09:03 AM
I think that it's a weak battery. I only have to drive 6 miles to work and back and haven't gotten it on the road to much recently.
I did a test over the weekend and let the car run for about 45 mins and now the steering wheel is working, consistently.
I've also been getting a "Check Rear Lights" issue as well. I checked all of the bulbs and even changed out the rear light holder assemblies. The seat, radio, rear view mirrors all work as designed.
Thanks for all of the posts - everyone's ideas are sound advice.
Old 11-14-2007, 09:13 AM
chivas's Avatar
it can drive a crazy man insane!
americandan.com
Old 11-14-2007, 11:06 AM
la528it's Avatar
la528it la528it is offline
Mein Auto: 2000 528it
I was having problems, as well. When I lowered the sun visor and opened the vanity mirror, the wheel, however, would move up. So I replaced the ignition switch and that fixed it. The wheel now goes down when I turn on the car, and up when I pull the key out.
I did however, change the battery within the same week... so it may have been the battery... I was not too concerned about the wheel not going up, at the time, that was the least of my worries!
Old 11-14-2007, 11:42 AM
bimmerd00d's Avatar
bimmerd00d bimmerd00d is offline
just havin a heart attack
Mein Auto: 1998 540i 6-speed
my battery was going out, and did this for the last 2 months until it finally failed on me. replaced it and all was well again. This will also cause goofy radio issues, and the seats to stop moving for a bit.
2011 535i xDrive M-Sport - 129k miles
2006 Mazdaspeed 6 - 128kmi
2016 Triumph Tiger 800 XRT - 4900mi
Old 11-14-2007, 01:06 PM
chivas's Avatar
you sig... but that means the Forester is going to be keeping up until 60?? that ain't right... lebians will look over at us thinking they have bigger balls then us!!! eh???
americandan.com
Old 11-14-2007, 03:25 PM
PJB. PJB. is offline
Mein Auto: 2000 528i (01/2000 mfg.)
+1 on the weak battery. Mine did the same right before the battery crapped out. Changed the battery and no problems since.
Old 11-14-2007, 03:43 PM
RMMJ's Avatar
RMMJ RMMJ is offline
Send a message via Yahoo to RMMJ
Mein Auto: Lots of cars....
Loose wire in the connector that is located in the seat? Happened to me once and upon removing the plastic cover around the seat I noticed the connector was not all the way in. I guess check that last if the other things above don't pan out.
Dana Point, California
2009 BMW X5
2000 BMW 528i
1986 Bertone X1/9
