'12 535I f10 coolant problems and code - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > F10 M5 (2012 - 2016)
The 5th generation M5 has the V8 S63 TU engine with twin turbos under the hood producing 550hp. The engine and DCT gear box pusses the M5 0-60 in just 4.2 seconds.
Old 01-24-2020, 06:15 PM
Kodiak17 Kodiak17 is offline
Mein Auto:
I have an engine code of 8200 and am leaking coolant really freaking bad. There is a part I suspect to be cracked but I'm not sure what to call it. It is a ball shaped part that is directly connected to the radiator before the coolant hoses down on the passenger side of the radiator and is fairly easy to get to. Does anyone know what this part is called so I can order it? Also the engine code reads "Map thermostat: Clamps open" I have no idea what that means. Any help is appreciated.
Old 01-25-2020, 07:29 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
I moved your post to the proper forum so that you can get some better help!
Old 01-25-2020, 07:38 PM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 Sport
Use realoem.com to find you parts. Enter your vin # to find the correct part.
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
