Advice for '06 750Li owner? - Bimmerfest - BMW Forums
Old 02-22-2017, 09:28 PM
sevenfivezero sevenfivezero is offline
750Li Lover
Mein Auto: 06 750Li, 13 750Li, 09 X5
I just purchased a one owner, dealer maintained, low mileage '06 750Li. 71k, new brakes, tires and full system flushes.
My question is how much money should I be putting aside and what major expenses approaching 100k should I expect?
Apologies if this is redundant to other posts but I figured what the heck, gotta start posting sometime. All feedback appreciated, thank you!
The Ultimate Driver...
Old 02-23-2017, 07:31 AM
u.nanimous u.nanimous is offline
Certifiable BMW Whackjob!
Mein Auto: 1999 740iS, 2008 335xi
Since you have a 2006 this would be a question better asked in the E65/E66 forum, this forum (E38) only goes up to the 2001 model year.
2005 Venture Extended LT - what else you gonna drive when you have 6 kids, cargo and still want better than 10MPG
1999 740iA - long term project/summer DD
2000 Impala LS - RIP 12/23/2016, officially totaled by insurance company
2001 330xiA - fXtXeX/son project - now April's car
2008 335xiA - winterbeater Impala replacement
2002 530i/5 - 2.5 years searching...and it is John's car
1989 535i/5 - the spare car
2002 325xiA - to be Charlotte's when she gets her license (?2019?)
Old 02-24-2017, 05:07 AM
tim330i's Avatar
tim330i tim330i is offline
Bimmerfest Founder
Mein Auto: Various
Your question has been moved to the E65/66 7 Series forum.
Old 02-24-2017, 08:24 AM
750Li Lover
Thanks!
Old 02-24-2017, 07:19 PM
Rick in Yuma's Avatar
Rick in Yuma Rick in Yuma is offline
Mein Auto: 05' 760li,94' H1,08'Smart
This seems to the trend as I see it here on the forum of items that crap out about 100,000 miles. $2500 for valve seals by a mechanic. There is a guy in New York State doing it for this.
Here's a list of some common problems.
https://www.bimmerfest.com/forums/sho...d.php?t=700549
Weep hole/ Center Valley water pipe repair. There are several ways of doing this. The dealer seems to be getting about $7000 to do it. Do it yourself with just water pump removal I think it's about $300. But while you're there you should just replace the water pump too.
https://www.bimmerfest.com/forums/sho...d.php?t=737208
All the pulley bearings and idlers should be replaced about that time too as they will fail.
Transmission service now. If it was not done at 50k miles.
Tune up now, don't wait till 100k it will run better.
You have the dealer service records, let us know what has already been done, it will help advise you further.
Can you do the repairs yourself? This will cut down on cost. A lot of the repair costs are in labor.
Welcome to the forum!
Old 02-24-2017, 07:32 PM
750Li Lover
Thanks Rick I don't work on engines myself but my friends son is a wizard and will work on it for me. I was really more curious what to expect. I have already found that the car transmission has a hard shift from.second to first. It feels like I got hit in the rear end. I actually pulled over the first time it happened. I read on the forum that this is common with this car and unfixablex and even happens with new cars. What is your opinion on this? Thank you.
Old 02-24-2017, 11:33 PM
Ltmax's Avatar
Ltmax Ltmax is offline
Mein Auto: 2008 750l
Posted this a while back and it's a pretty good place to start.
https://www.bimmerfest.com/forums/sho...ht=dirty+dozen
Old 02-26-2017, 07:09 AM
FatBoy613 FatBoy613 is offline
Mein Auto: 2004 745i
The 2-1 transmission problem is just a bad guibo joint that needs to be replaced. Try doing a transmission adaptation reset and see if it improves things a bit. Mine needs a new guibo as well, but after the reset it got a little better
Old 02-26-2017, 12:05 PM
750Li Lover
Thanks Fat boy. I will try that. One other question. The car has trouble with reverse sometimes. It basically just shifts into neutral. I have to turn the car off and restart it. It's embarrassing at the least and a pain as well. One time the transmission fault light came on and that scared me. Could the bad guibo joint be doing that in your opinion. Thank you VERY MUCH!
750li, maintenance, repairs
