n54 cold start whine - any help diagnosing? Video included - Bimmerfest - BMW Forums
Old 01-02-2018, 11:23 AM
jasonwiley65 jasonwiley65 is offline
Mein Auto: 1990 e30 325ix
Hello all. I'm brand new to the e90 game. Just picked up my first - a 2007 335i 6 spd. Car was a one owner, has 113,000 miles on it, and has a ton of maintenance done by PO.
Here is a clip from a cold start. I have this high-pitched whine, but it's only on a cold start and it goes away completely after the engine is all warmed up. Any ideas as what that noise could be?
Any thoughts / advice would be greatly appreciated.
Thanks all!
Old 01-02-2018, 11:25 AM
acoste's Avatar
acoste acoste is online now
Mein Auto: 2010 550i MT
I have the same sound ever since some coolant spilled onto the alternator.
Check the pulleys on the serpentine belt, make sure they are ok.
2010 BMW 550i MT
2003 BMW 325i @216k and counting
1998 BMW 528i MT @ 231k //sold
1997 Saab 9000 //sold
Old 01-02-2018, 11:45 AM
Roger that and will do. Did you notice the noise going away on yours after your car warmed up too?
Old 01-02-2018, 11:51 AM
acoste's Avatar
It goes away in a minute. And I can hear it only at the first start in the morning.
It was loud right after the spill but it quieted down months later and now I can hear it only with the windows down.
2010 BMW 550i MT
Old 01-02-2018, 12:22 PM
Nachfolger Nachfolger is offline
beemlyfe
Mein Auto: 2009 335i
Sounds like metal grind from inside rather then a belt squeal. Regardless, check what Acoste said. His knowledge succeeds mine.
Genesis 3:28: "And next he proceeded to form the naturally aspirated inline six engine and place it in a 50/50 weight distribution rear wheel drive chassis. It was given the spark of life, and the exhaust note was good."
(-) 2016 S1000RR, Race Package, Dynamic Package
(-) 2011 535i xDrive
(-) 2011 335i, Automatic (), Convertible
(-) 2009 335i, M-Sport, Manual, Dinan Stage 2, Performance Package
(-) 2005 CBR600RR
(-) 2003 330I, ZHP, Manual (my pride and joy)
(-) 1997 CBR600
Old 01-02-2018, 12:38 PM
gbalthrop gbalthrop is online now
Mein Auto: 2007 328xi E91
...Here is a clip from a cold start. I have this high-pitched whine, but it's only on a cold start and it goes away completely after the engine is all warmed up. Any ideas as what that noise could be?
What I am hearing when playing your clip is a "high-pitched SQUEAK" that sounds like belt squeak (very slight slippage on crank pulley or other driven pulley). I would test by having someone turn the steering wheel lock to lock as you listen near the serpentine belt with hood up, and see if sound changes with additional force required to turn P/S pump. Also remember it takes more force to rotate the alternator immediately after startup.
Check the belt for cracking/glazing, and if the belt shows wear/damage, replace it -- for $20 better safe than sorry. If the prior owner provided service/parts records, when was it last changed?
George
Old 01-02-2018, 02:28 PM
Ben22101's Avatar
Ben22101 Ben22101 is offline
Mein Auto: BMW 323i
Iím with George on this one, sounds like a belt. Inspect the idler pulley also.
Sent from my iPhone using Tapatalk
Old 01-02-2018, 04:13 PM
gT-BMW gT-BMW is offline
Mein Auto: 325i
This is a common noise but its often a different problem. no one squeak is the same unfortunately but its easy to pin point as long as you have good trouble shooting skill and common sense. time to get dirty. remove the belt inspect it check for cracks. turn every pulley that belt turns by hand. any rough spinning, in out play, or hard to turn by hand etc is bad and need replacement.
i had a customer with a crv that made a similar noise. it was the ac compressor clutch bearing. this unfortunate soul had the black death.
Old 01-03-2018, 11:27 AM
Thanks for the info everyone. I have an open recall on the car anyways, so I'm going to send it into the dealership and see what they think as well. I'll update the thread when I get word on exactly what it is. Hopefully it will help someone else out in the future.
335i, cold start, engine whine, n54
