Active Blind Spot problems - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > F80/F82/F83 M3 and M4 (2015 - Current)
F80 BMW M3 sedan, F82 BMW M4 coupe and F83 M4 convertible forum. This 5th generation M3 and all new M4 features a 3.0 liter twin turbo engine (engine code S55) 425hp and 406lbs of torque! Heavy use of light weight materials makes this generation lighter and faster then the outgoing E9x M3.
Old 06-06-2018, 09:17 AM
andrew1cohen andrew1cohen is offline
Mein Auto: 2015 M4 Convertible
Hi All:
Love my (used) but new to me M4 Convertible. Just an amazing car, both as a DD around SF (a surprise how mellow i can set up the car), and driving it heard on the winding roads around here. I am taking track classes laster this summer.
One problem though: My Active Blind spot detection system regularly stops working. I can often turn it on and off and it will start working. Nevertheless, it is not working most of the time,.
Does anyone have this problem and any try at home fixes . before i bring it to the dealership?
Thanks!
andrew
Old 06-07-2018, 02:45 PM
neightsta neightsta is offline
Mein Auto: 2018 M4 ZCP
Yes. I have the exact same issue (non convertible). Is this the message you're seeing?
If it is, don't bother going to the dealer. They said it's a known issue and it has to do with the shape of the car and the way the bumper accepts/reflects light and shade and it's completely normal.
I'd have never taken this feature if I had a choice, I picked up a model off the showroom floor and it just had it...but now that I have it, I want it to at least work properly, you know?
Old 06-08-2018, 02:21 AM
FCBayernFTW's Avatar
FCBayernFTW FCBayernFTW is offline
Extended Euro Delivery
Mein Auto: '18 X3
The BSD system is inconsistent on the M4. Often, it only detects traffic closing in on you from behind, not as you're passing, especially on the right. The left side is more consistent.
I took it to the German dealer and they said it was normal.
-2015 BMW ///M4 Austin Yellow (sold)
-2017 Mazda CX-5 Grand Touring Soul Red Premium
-2018 BMW X3 xDrive30i Phytonic Blue Metallic - ZCV, ZDA, ZPK, ZPP, ZPX
Old 06-08-2018, 05:47 AM
I've also noticed that too. Eventually they'll replace/upgrade the units that sit behind the bumpers. Can't imagine this is acceptable from a delivery standpoint with it being this flaky.
Old 06-08-2018, 02:16 PM
Just a heads up, I finally got the ABD to shut off on my way to the BMW dealership today and even had a road test with one of the techs. We turned off the car and turned it back on so I could re-enable the ABD and literally a minute later after pulling out of the parking lot, it failed again. He said nope, this is not right and he was uninterested in finding any fault codes that the other dealer I went to said was required. So, they're going to strip it apart and change out whatever they need.
Just a FYI to OP, find a SA who will get a line tech or foreman (in my case) to get in the car when it's failed and let them take a look.
active blind spot detection, convertible, m4
