Leaks around the turbocharger - Bimmerfest - BMW Forums
Old 03-03-2019, 06:31 PM
mamet007 mamet007 is offline
Mein Auto: 2010 BMW X5 35D
E70-X5-35D: Engine M57
Hello everyone, I thought I was done with the oil leak by the flywheel that was caused by a swivel flap by injector 6 (@Sunny/@Doug thanks for your help on the other thread). Now I see an oil leak by the turbocharger. it looks fresh looking like oil. could be gunk from the seals as well.
Any pointer or guidance on how to start looking into it? Thanks!
Old 03-03-2019, 07:04 PM
sunny_j's Avatar
sunny_j sunny_j is offline
bmw addiction
Mein Auto: X5d
I would clean everything up and see where it comes from. It can be the oring that connects the air pipe to the turbo, , CCV hose, charged air pipe and or gasket. Or the oil lines or drain lines
2012 X5d | Deleted & BRR Tuned | DWR TCU Tune | 10.25" Android 8.1 Screen
Build Log
https://www.bimmerfest.com/forums/sh....php?t=1290337
Old 03-03-2019, 07:26 PM
k, thx! do you know any DIY to get to the Turbo to clean around it, I am looking at the newtis but not sure if it has everything.
Old 03-03-2019, 07:46 PM
sunny_j's Avatar
bmw addiction
Mein Auto: X5d
maybe some degreaser might help. it's a slow process and don't rush it because that's when things break.
I had a bag bad o ring and ccv hose was cracked
Build Log
Old 03-04-2019, 02:00 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
NewTIS does not have everything and is not intended to have everything. In each and every case a technical writer was paid to produce the procedures.
In every case there must be a clear and precise objective before the work is packaged.
Old 03-04-2019, 10:56 PM
maybe some degreaser might help. it's a slow process and doesn't rush it because that's when things break.
you are right I was very frustrated with the vacuum hoses that seem to be glued in. in the process of carefully trying to take them off, i snapped one of the Boost Solenoid Valve connectors. is there a way that I can buy the connectors only?
Here is some of the images I took, can you tell me your thoughts?
ID:	842603   Click image for larger version
Old 03-05-2019, 01:33 AM
sunny_j's Avatar
bmw addiction
Mein Auto: X5d
Can you post a realoem link/diagram with the broken part?
Build Log
Old 03-05-2019, 01:42 AM
Nuclear engineer
Yes. They are commodity connectors, perhaps from AMP, and listed in RealOEM.
The problem will be inserting installing the pins or plugs.
https://www.newtis.info/tisv2/a/en/e...system/4MjcZMt
The connector may have a 'X' designation.
https://www.newtis.info/tisv2/a/en/e...er-connectors/
Old 03-05-2019, 04:33 AM
@Sunny and @Doug honestly I truly appreciate your help on this. every time I felt like I was over my head I thought of you guys and I kept on going. God willing things will work out.
most of the Vacum lines are toast. to reinstall, do you clue them in? if felt like they were glued for some reason.
broken connectors:
part #: 11658509323
The top connector to the oxygen sensor connector the one that provides power and circuitry to it: 13627801158
Any thoughts on the oil residue; do I need to continue the path of removing the turbocharger?
Name:	Screen Shot 2019-03-05 at 7.20.47 AM.jpg
ID:	842639   Click image for larger version
Name:	Screen Shot 2019-03-05 at 7.14.12 AM.jpg
ID:	842641   Click image for larger version
ID:	842643   Click image for larger version
Old 03-05-2019, 04:44 AM
Nuclear engineer
No, they should not be glued. They are vacuum lines which atmospheric pressure should clamp tighter in use.
They are both plastics which plasticizers are volatile and the plastic probably diffuses under elevated temperature. 'I' might think a bit on an anti-seize lubricant on reassembly to make reassembly easier. But how often do you expect to work in the area, to pull the hose off again?
Old 03-05-2019, 05:12 AM
Thanks! is there a connector replacement for the oxygen sensor plug?
Old 03-05-2019, 05:19 AM
Nuclear engineer
connectors at RealOEM
http://www.realoem.com/bmw/enUS/part...=&q=connectors
e70, oil leak, turbo charger
Similar Threads
760i engine leaks David.W 7 Series - E65 / E66 (2002 - 2008) 1 03-17-2019 06:47 AM
Recurrent oil leaks, warranty roc797f X3 F25 (2011 - 2017) 0 01-25-2019 12:23 PM
Water leaks into the passenger floor DonBravo E90/E91/E92/E93 (2006 - 2013) 3 10-23-2018 04:48 PM
Oil leaks easy to fix? Jlchenier48 E36 (1991 - 1999) 3 05-08-2018 03:19 AM
Service info needed for 60k mile interval Maximus 3 Series & 4 Series 5 04-04-2004 05:53 PM
