Z3 M Roadster Clutch adjustment - Bimmerfest - BMW Forums
Old 09-10-2012, 02:48 PM
HANSONCLN HANSONCLN is offline
Mein Auto: 99 m Roadster
I just picked up a 99 m with 42000 on it clutch grabs 1/16 0ff the floor is there any adjustments that can be made i bleed the system and no change
Old 09-10-2012, 09:50 PM
dkl's Avatar
dkl dkl is offline
Mein Auto: E53 X5, E86 Z4MC
Definitely very odd. Are you sure the previous owner didn't modified the clutch stop?
Old 09-11-2012, 07:51 AM
smayo964 smayo964 is offline
Mein Auto: 1999 Z3 Roadster
I have the opposite problem on my Z3 where mine releases to far off the floor for my liking. Asked about if there was any way to adjust it and never really got an answer.
Sent from my SGH-T989 using Bimmer App
S. Maykowski, Columbus MS.
My '99 Z3 Alpine White 2.8L Speed Buggy
Old 09-11-2012, 10:50 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Nope, no real adjustment.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 09-11-2012, 12:17 PM
Wertles Wertles is offline
Yoda with a library card
Mein Auto: 1999 M Coupe
The only adjustment is a plastic screw on the footwell behind the pedal. If you can screw it in, that will give you a little more room. If it is all the way in, you may have other issues that require a proper bleeding of the slave or more extensive repairs or replacement.
1999 Boston Green M Coupe
2002 Z3 2.5 Automatic Roadster
2013 Ram 3500 Crew Cab Dually, 850 ft/lbs torque, stock and staying that way
1995 318i spray paint red, 170,000 miles and climbing
Old 09-11-2012, 12:19 PM
You can also adjust the screw out to give you less pedal travel. I bought this clutch stop as it is larger in diameter than the stock one, eliminating my pedal from slipping past it. The only down side of it is that it doesn't screw down as far as stock so in the OP's case, it would make matters worse.
http://leatherz.com/Merchant5/mercha...3_Transmission
Old 09-11-2012, 02:13 PM
SUNZOUT SUNZOUT is offline
Mein Auto: '00 M Roadster
Bleed the clutch to ensure that there is no air in the system
TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit
Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix
Old 09-11-2012, 02:40 PM
Bob2.8 Bob2.8 is offline
Mein Auto: 1997 2.8
It may be the clutch line
https://www.bimmerfest.com/forums/sho...lutch+bleeding
Here is a discussion on how to bleed the clutch also
Old 09-14-2012, 04:18 PM
Fixed it
Ok so took advice from a couple of different sources and bought the ss line which also removes the valve that limits clutch engagement and what a difference
Clutch is 1-2" off the floor when it starts to catch feels and awsome
Still however i could not figure why you would need to remove the slave of the trans to bleed it BMW is smarter than that, i actually saw a picture someone took of a slave cut open and the bleed led to the top of the cylinder so i did it on the car
Old 09-15-2012, 06:47 AM
awdonald awdonald is offline
Mein Auto: 00 z3 m coupe
Try a "reverse bleed"...fill an oil can with brake fluid and pump fluid "up" the bleed nipple. Obviously that oil can becomes a "dedicated" device.
