03 E39 (525i) Engine Regular Maintenance - Bimmerfest - BMW Forums
Old 10-05-2016, 04:34 AM
mutyo051026 mutyo051026 is offline
Mein Auto: 2003 BMW 525i Sedan
I have 03 525i sedan and it has about 160,500 miles on its odometer. I bought this car last May when it had around 150,000 miles on it, and since then I have had no issues on the engine. I have changed the motor oil once, and I regularly check other important fluids such as brake fluid, coolant, etc... But since I will probably keep this car at least 3 more years, although I do not have any issues on the engine right now I want to know the appropriate ways to maintain it so that I can maximize its life span.
So what else should I do regulary other than changing the oil and filter? And how often?
Old 10-05-2016, 05:44 AM
GrannyApple's Avatar
GrannyApple GrannyApple is offline
Nothing to read here...
Mein Auto: 2001 525i 5 spd
This information is readily available in the faq, wiki, in bluebees crosslinking posts and in searches both in site and in google by using keywords like "e39" or " bmw m54" followed by whatever your searching for like "maintenance" or the like. Not trying to offend but if you're really set on owning this car definitely try to read up on everything already available. Not only will it help you understand your car better it's really interesting.
These engines are very reliable as long as they have coolant and oil. Think about it as a Toyota 5fse engine but instead of worrying about a timing belt failure you worry about a cooling system component blowing and overheating the engine So you would want to make sure hoses, thermostat housing, water pump, radiator and the mechanical fan are in good shape. The hoses should be nice and smooth with no cracking when you squeeze one. The waterpump well as long as your not overheating and there's no leakage from it is should be good. Same with the radiator. The mechanical fan should freely spin when you give it a push with the engine off.
Other than that give it the same care you would give any other engine. Check spark plugs, air filters, check the vacuum lines for any leaks and always have any eye out for any developing oil and coolant leaks. As long as you don't neglect and ignore issues the engine will last ya.
The Crappitto-Stockitto-Baseito
**Word of Caution**
My knowledge is limited. Anything I write in my posts may or may not be accurate. To be honest I think its all crap.
If you live near me and need help reading codes give me a buzz.
Old 10-05-2016, 06:02 AM
rbelton rbelton is offline
Banned
Mein Auto: E39
Check out all of the E39 maintenance videos on my YouTube channel: https://www.youtube.com/channel/UCd0...XbkR0ap6uzX7yA
Old 10-05-2016, 06:19 AM
TheHockeytowner's Avatar
TheHockeytowner TheHockeytowner is offline
RIP #9
Mein Auto: 2003 525i
Great advice from Barracuz.
I too bought a high-mileage 2003 525i, that was over 6 years ago.
Once I established a solid "base" on my car (got it running really smoothly [VANOS seals, CCV, DISA, cleaned ICV, replaced all vacuum hoses, fuel injector cleaning, etc.], avoided catastrophic failure [complete cooling system refresh]), I created a maintenance schedule (see attached). The intervals come in part from Mike Miller's "old school/lifetime maintenance schedule" but also from the old service sheets from BMW. Some of the items on the list have a shorter interval than the Mike Miller schedule, others have a longer interval.
  • I run a 7.5k OCI; I used to run a 5k interval. Any modern synthetic, approved for the E39 or not, should last at LEAST 7.5k. I do not send my used oil to Blackstone Labs.
  • I replace the air filters (engine and cabin) every 15k. I also try to pour a bottle of Techron fuel system cleaner in every 15k, BEFORE I do the oil change.
  • Diff, manual transmission, and power steering oil get changed every 30k -- but in practice, the power steering is more like 60k due to my laziness
  • I also replace the drivebelts every 30k, but this is probably too soon. Same with spark plugs, probably could get more than 60k miles out of them.
  • O2 sensor replacement is listed as every 90k, but in practice/since replacing all 4, it's more of a "as the sensors fail" kind of thing.
  • I try to follow the coolant and brake fluid replacement intervals, but not always. Before I did brakes on the car last year, the brake fluid was at least 5 years old
  • I do not perform routine/preventative cooling system refreshes -- I work on the car so often (whether maintenance or repair) that I am constantly checking the condition of those components. I do not replace anything unless it is obviously ready to give up the ghost. A gamble maybe, but so far so good.
It's a lot of work (and expense) but I get routine compliments from passengers re: how smoothly and quietly the car runs. Oil consumption is around 1qt/5-6k miles @ 243k. Cosmetically it's a total pig, but it's like the Millennium Falcon: "She may not look like much, but she's got it where it counts."
Lastly, a one- or two-quart oil can with a flexible spout is truly your best friend. You can then buy Castrol EDGE 0W-40 A3/B4 in bulk (5qt. containers) for ~$4.50/qt on Amazon and never muck around with single quarts again.
Go Wings!
Old 10-05-2016, 04:36 PM
JaxPlanet's Avatar
JaxPlanet JaxPlanet is offline
Mein Auto: 2000 528iAT
Go to Bavauto.com's Tech Tips section to download a maintenance schedule.
Get the "BMW 5 Series Service Manual 1997-2003" from Bentley Publishing.
Go to RealOEM.com to identify parts
Here are some good parts suppliers: Autohausaz.com, FCPeuro.com, BavAuto.com, GetBMWParts.com and TurnerMotorsports.com
Old 10-05-2016, 04:53 PM
Great advice! Thanks!!
Old 10-05-2016, 05:31 PM
I will! Thanks!!
Old 10-05-2016, 05:32 PM
Thanks for sharing your maintenance schedule. That would be very helpful!
Old 10-05-2016, 05:52 PM
Thanks for the info!
Old 10-05-2016, 06:01 PM
RIP #9
No problem. I would still try to find a copy of Mike Miller's schedule. If you do track days/autocross, you'll definitely need to replace the brake fluid more often
Go Wings!
525i 2003, e39 2003, engine, maintenance
