Problems to look for in a 2003 E39 - Bimmerfest - BMW Forums
Old 12-13-2017, 03:19 PM
ZombieMachine ZombieMachine is offline
Mein Auto: Want a 540
I love the 540 E39. I finally found a really clean one but I don't know much about this car and was wondering if anybody could recommend some issues to look for?
Thank you!!!!
Old 12-13-2017, 04:39 PM
dms540i's Avatar
dms540i dms540i is offline
Mein Auto: 1999 BMW 540iA
This forum has everything you need in the “stickies” section up top. See the thread called “how to easily find information on your e39 ...” or something witty like that. If you look through it you find a lot that a former forum member called “Bluebee” compiled. Take a look. She did a great job getting to the bottom of many many issues and linking the best diy threads together with amazing clarity. Here is one entry that is well worth the read. Brand new to BMW ownership- what to do first?
https://www.bimmerfest.com/forums/sho...d.php?t=850913
BMWCCA#401441
Old 12-13-2017, 04:49 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Browse the three Stickies on the home page. If you are serious about this car, locate a BMW specialist for a pre-purchase inspection.
Both the I6 and V8 have their own set of issues. If the car is without service/repair records, it'll be a problem.
Read this document. It's dated, but has a good amount of info:
https://www.bimmerfest.com/forums/at...4&d=1314737014
Old 12-13-2017, 05:29 PM
540 M-Sport's Avatar
Mein Auto: M550i, 540M-Sport, Scud
I agree with edjack. You should use your own visual and test drive to sift through the cars not worth of consideration. If you come across a "serious contender", that has some good history, drives well, and the owner looks like one who cares for his cars, THEN invest in having a "pre purchase" inspection done. This will cost from $200 to $400, as it will entail at least a couple hours to go over the car. Seriously, this can save you thousands, and prevent a potential disaster...and even if the inspection comes back less than stellar, if it is a nice car otherwise, use the inspection as negotiating power to drive a better deal.
BUT, you should find a good independent BMW service specialist in advance. Explain that you are looking to purchase a car, and have them inspect it....often times they can be a good resource to help you find a car....perhaps they know a good customer looking to sell. Plus, a trusted BMW service specialist will pay you back in spades helping you steer around a bad car, and ensure proper maintenance and avoid future problems on your purchase.
The basic concerns on any higher mileage BMW would be the following: brakes, oil leaks, wheel bearings, door seals, rear ball joints, suspension control arms (and thrust arm bushings), water leaks from door vapor barriers, seat rails (seat rail twist), sunroof drains, and general operation of radio, nav, AC/HVAC, and other accessories. Also, condition of dash and radio pixels...though that can be fixed by sending them out, around $250 to $350 for each.
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, Eibach front and rear anti-roll bars, M5 rear traction rods, H&R 15mm wheel spacers, ST X (KW) coilovers, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, Zimmerman rotors, Dinan Stage 1 software, USA Spec Ipod/Iphone integration.
Old 12-13-2017, 06:06 PM
Thank you!!
Awesome!! Thank you guys!!
buy a bmw
