E39_530iTurbo Build - Bimmerfest - BMW Forums
Old 11-14-2018, 08:53 AM
Keahi_e39 Keahi_e39 is offline
Mein Auto: 2002 BMW 530i M-Sport pac
E39_530iTurbo Build
Hello, everyone. I have been searching for any new information about adding a Turbo to my M54b30 engine. I live in New Jersey and want to know if there are any dyno tune shops close to me that can tune it. Building the turbo kit seems to be the most cost effective way of going about the turbo setup. I really need helpful advice with the best way of going about this build without wasting unnecessary money. I want to make 400whp at least.
Old 11-14-2018, 09:23 AM
Mr.Yuck Mr.Yuck is offline
Mein Auto: 99 540i
I doubt there is a drop in kit. You are going to need a bunch of things. Not sure what compression yur engne is or what the psitons are made from. That will have a lot to do with how much boost you can run. You are also going to need bigger injectors, MAP work and of course your computer will need to be reprogramed. I hope you can do the fab work, that adds up quick. If you cannot you might want to look at a supercharger kit. Or maybe this....
Old 11-14-2018, 11:07 AM
Old 11-14-2018, 11:09 AM
My buddy told me that I should do the LM7, LQ4 or L33 swap. If I did the swap what features will I be losing? I want everything to work as it should, like all gauges, A/C and even OBD2 so I can see when it throws a code. Can you tell me about your setup, HP and price?
Old 11-14-2018, 11:11 AM
u.nanimous u.nanimous is offline
Certifiable BMW Whackjob!
Mein Auto: 1999 740iS, 2008 335xi
Unfortunately the most cost effective option to increase power is to start with trading up to a 540 and then add power to that.
But sticking with the 530 what you need to search is power mods for an E46 330. There are entire websites dedicated to this. As Mr. Yuck said though you'll likely have to beef up your internals first for some real boost and superchargers are off the shelf kits for an E46.
sent from the future using the bimmerfest app embedded in my neural implant
2005 Venture Extended LT - what else you gonna drive when you have 6 kids, cargo and still want better than 10MPG
1999 740iA - long term project/summer DD
2000 Impala LS - RIP 12/23/2016, officially totaled by insurance company
2001 330xiA - fXtXeX/son project - now April's car
2008 335xiA - winterbeater Impala replacement
2002 530i/5 - 2.5 years searching...and it is John's car
1989 535i/5 - the spare car
2002 325xiA - to be Charlotte's when she gets her license (?2019?)
Old 11-14-2018, 11:18 AM
Mein Auto: 99 540i
I'm just running a stock 540i sport 6 speed. BUT there are plenty of SBC swaps around. I'm not sure if there is a "kit" around. I'd check ebay, if there is a drop in kit...it will be on ebay. If you want affordable boost, I'd look into a supercharger. Keep the boost around 8psi and you should be good with stock internals. It isn't going to make 400RWHP thou. FWIW I'm not up on these that much as I am old school muscle cars, but 400RWHP is not easy on driveline parts.
Old 11-14-2018, 12:26 PM
The plan was to upgrade the bottom end to Forged Pistons & Rods which VAC has a Turbo build kit that will lower CP to 8.5:1. It also comes with ARP & Raceware main studs and Rod bolts, which is rated to handle 700hp.
For the LS build I saw that Sikky makes a swap kit so I can use my 5 speed. I'm worried about all the other features and cost for the swap. Can you shed some light on what you did
Old 11-14-2018, 12:32 PM
I stayed away from the 540's because most of them were ran through the mud. I do see the inline 6's pushing 500whp and above with minor internal engine improvements and adding a turbo. They have posted the videos on youtube, but I started this thread to see about any updated information about doing the turbo on a 530
Old 11-14-2018, 01:49 PM
Mein Auto: 99 540i
that was a pix from the internet. I have a stock 540i sport 6 speed. and if I did a swap...It would be with a Gen III Hemi, I'm a mopar guy.
Old 11-14-2018, 01:50 PM
Mein Auto: 99 540i
A guy at tje local track has a 2 door 3 series with a BIG turbo. He kept breaking stuff. Car now has a Power glide trans. I think he is way in the 9's.
Old 11-14-2018, 06:17 PM
five.two.five five.two.five is offline
Mein Auto: 2002 525I
Email: [email protected]
Web: www.mosselmanturbo.com
Old 11-14-2018, 09:42 PM
atobe atobe is offline
Banned
Mein Auto: 00 528, 01 540
You can try and follow this guy, he's doing a zhp swap and supercharger kit but you might get some ideas how much work and labor is involved.
https://www.bimmerforums.com/forum/s...ine-Swap/page2
Old 11-16-2018, 09:25 AM
Those LS swap kits are really meant to be done in a 540.
For the ZHP they just put in different cams and retuned it, still a 3L M54. But hey, look at post #8 and you'll see OP doesn't want to hear anything about an E46.
Old 11-16-2018, 09:37 AM
Mein Auto: 99 540i
does the LS bolt up to the 6 speed pretty easy?
Old 11-16-2018, 09:46 AM
Post #7 OP said the Sikky swap kit lets you keep the BMW the 5 speed, it would be hard to believe they didn't have something for the 6 speed. It would be quite a coincidence if the 6 speed bolted directly up to the LS so probably a special bell housing, is that different between the 5 and 6 speed transmissions?
530 turbo, 530i, e39, e39 530i, e39 530i performance tune, e39 530i turbo, turbo
