Level Control System Malfunction - Bimmerfest - BMW Forums
Old 11-15-2018, 08:51 PM
tjosue tjosue is offline
Mein Auto:
Hello all, I'm new to the forum, but have really appreciated all of the good advice I've gleaned over the years from the users here.
Here is my situation. For a while I had leaking air struts. Each time I started the X5, it would pump them up, and I thought this was normal. One day my son and I were running errands and I hit a huge pot hole and the left air strut burst. I did a little research on these forums and was able to easily replace both old air struts with Arnotts. This worked great, everything was back to normal, no malfunction lights, great ride, good to go.
Then, this happened: I took the X5 to the dealer to troubleshoot a front-end problem (a weird kind of shudder, but that's a different post) and while it was at the dealer, the compressor stopped working and the Level Control System Malfunction indicator came on. Since they wanted $1200 for a new compressor and $600 to install it, I decided to replace the compressor myself, which was a relatively easy job. Again, I got an new Arnott compressor (less than $600), did the installation, and voila, it won't turn on. I checked the associated fuses, and they are good.
So, I read on a thread somewhere that I should disconnect the battery and let the system reset, and now I have two errors:
Level Control System Malfunction!
Chassis Stabilization Malfunction!
The compressor still wont turn on and the X5 sits with two malfunctions. And, to top it off, my wife is seriously annoyed with me and questioning my mechanic skills
What I want to know is after installation of a new compressor, is it normal that it won't turn on? Does the error need to be cleared or something reset in the computer before it will work?
Is there a tool I can purchase that allows me to reset the indicator, or further troubleshoot the problem.
Anyway, if you made it all the way through this novella, thanks for reading and I look forward to your sage advice.
Old 11-17-2018, 01:38 PM
mitocross mitocross is offline
Mein Auto: E70 3.0sd
It could be as simple as checking the fuses and clearing the codes before restarting the car again. You'll need some kind of diagnostic tool to do this - Carly for BMW is the simplest I think.
compressor, e70, lcs, x5
