2019 X5 USB port - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X5 G05 (2018 - Current)
G05 BMW X5 produced between 2018 to Current. Discuss the G05 X5 with other BMW owners here.
Old 02-29-2020, 01:53 PM
claud 3 claud 3 is offline
Mein Auto: 2014 EBII 335i M-Sport
2019 X5 USB port
Is the 2019/2020 X5 USB port 2.0 or 3.0?
2020 Blue X3 30 X MS & 2019 Black X5 X40i
BMWCCA # 381930
Old 02-29-2020, 04:12 PM
TheTurtleBoy TheTurtleBoy is offline
Mein Auto: 2019 X5 40i
I think I read the type A port is 3.x. Here is the charging info in case that helps also.
Name:	Screen Shot 2020-02-29 at 5.12.05 PM.jpg
Old 02-29-2020, 06:05 PM
It has nothing to do with amps. The 2.0 is smaller than the 3.0. the 3.0 will accept a 2.0 connector as well as a 3.0, but not the reverse.
BMWCCA # 381930
Old 02-29-2020, 06:08 PM
The charging info was provided as additional information. Your understanding of the USB 2.0 and 3.0 is not correct. I suggest you review some info on the web as you seem to be confusing the usb level with the connector type.
Old 03-01-2020, 10:04 AM
GaryK4 GaryK4 is offline
Mein Auto: Audi Q7 2017
Correct. 3.0 supports a data transfer rate about 10x faster than 2.0. It is not the connection type.
Old 03-01-2020, 11:09 AM
Everything I have read says a USB 2.0 port is a different size than a USN 3.0 port. The 3.0 port can accept and use a 2.0 connector, but not visa versa. It would seem that at least my 2019 X5 can use a 3.0 memory stick.
BMWCCA # 381930
Old 03-01-2020, 12:25 PM
Try this link, it may help.
https://www.conwire.com/ultimate-guide-usb-cables/
Old 03-01-2020, 12:58 PM
jadnashuanh jadnashuanh is offline
Mein Auto: 535ix-drive GT; i3 BEV
Basically, the host end of the USB cable, except maybe on a type C, remains the same size and shape. The port's digital hardware and software support determines the data speed and power capability. While there are lots of different device ends, mini, micro, etc., the other end is the same, at least in how it looks.
The higher the version number, the faster it can pass data, but all of them are backwards compatible, so you don't have to worry about the host end...it will still work with lower numbered interface devices, just won't reach the capacity of the host.
Jim DeBruycker
