Running problem - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 03-21-2020, 04:50 PM
steeler80 steeler80 is offline
Mein Auto:
Running problem
My friend has bought a 1993 325i that if you're in gear runs fine, but if you're approaching a red light then you have to gear down because if you put the brake and clutch on it tries to die. If you're idling with the clutch depressed and give it gas the car tries to die. The previous owner told him that it was due to a new alarm system being installed. Is that possible or could it be the mass air flow sensor? Thanks!
Old 03-21-2020, 10:12 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Extremely unlikely it has anything to do with the alarm system. Sounds like a vacuum leak. The car is running very lean, a very undesirable condition.
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
Amateur Extra ham radio operator KO4AXN, see you on 40 meters!
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 03-22-2020, 11:10 PM
ruben7 ruben7 is offline
Mein Auto: 98 328is
Had this problem a couple months ago. It ended up being the intake boot hose behind the MAF that had a massive crack hidden underneath. Common problem with this part.
Old 03-23-2020, 07:11 AM
M-technik-3 M-technik-3 is offline
Mein Auto: 88 M3x2 86 330i 4 e36's
Also check the IAC Idle Air Controller those early lines break and clean the inside of it. Cars that go extended periods without oil changes gum up and work poorly.
Old 03-24-2020, 05:56 PM
Mein Auto:
Thanks for the ideas! I've forwarded them on to my friend.
