92 e36 m54bu25 swap - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 04-04-2020, 11:32 PM
kazern kazern is offline
Mein Auto:
92 e36 m54bu25 swap
So I have a 92 e36 and just got a m54 which come with the pedal,dme plus its full wiring harness and I was just wondering what way to go about converting it to my shell I still have the stock 320i engine harness if that makes life easier for me.
I know I could buy the harness off someone who does them but honestly for almost the same price as my engines worth I feel its a bit over the top if I could do it myself over a few weeks.
Also yes i have someone to sort the dme out for me but any other tips would be handy thanks.
Old 04-05-2020, 02:54 PM
moneytaker94 moneytaker94 is offline
Mein Auto: turbo e36
You easiest bet is to remove the stock 320i harness and retrofit the m54 harness in there. Many sensors will be different to start with and locations of accessories may be different between the 2 engines
Sent from my SM-A530W using Tapatalk
Old 04-05-2020, 07:21 PM
Mein Auto:
Like as in take the chassis plugs and wire the m54 harness to them?
Old 04-06-2020, 05:09 PM
M-technik-3 M-technik-3 is offline
Mein Auto: 88 M3x2 86 330i 4 e36's
Kazen? You are live abroad correct? not US because you mention 92 320i. First thing is I think is you are a non vanos engine correct? I would pick through http://e36.de
e36, m54 b25, skrt
