E-Sys does not start - Bimmerfest - BMW Forums
Old 12-09-2016, 02:19 PM
ben1984 ben1984 is offline
Mein Auto: BMW F11 525d
Hy guys,
my name is Benedikt and im from Germany and driving a BMW F11 LCI 525d
Today ive downloaded E-Sys 3.26.1 with PSDZ data 59.4
If i start it the normal way everything works fine -> ok i know that i have the trimmed CAFDs and so ive downloaded the premium launcher V 2.6.2 124.
Installed the launcher, choose the location where the *.ext file should be saved. Entered password twice, marked my model F011 and pressed "launch". so far so good.
5 seconds later E-Sys is going to start. At the point "creating log file" within the starting image nothing happens any more. The starting picture is gone and nothing appears any more.
No error message -> nothing.
Has someone of you guys any idea?
Thank for your help
best regards,
Benedikt
Old 12-09-2016, 05:05 PM
Almaretto's Avatar
Almaretto Almaretto is offline
Super Moderator
Mein Auto: Test Vehicles
Which windows are you using? Did you make sure you have latest .NET Framework installed and are not running any third party antiviruses or firewalls?
Old 12-09-2016, 05:17 PM
Hey,
I'm using Win 10 64 bit.
I guess i'm using a valid net Framework. Which one is needed?
I just use the avaria anti Virus..
And for testing i've also disabled avaria.
And i've tried to start the launcher with Win 8 mode
Br
Benedikt
Old 12-09-2016, 05:44 PM
Do i have to Do the normal esys installation?
Currently i ve changed changed a bat file and added a jar file. But Not the tokenmaster.jar
Maybe thats the reason why the launcher cant start esys ???
Or am i wrong with my assumption?
Br
Old 12-09-2016, 05:59 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
Br
PM sent. Delete all you have and start over. You must use E-Sys Launcher with normal E-Sys install, as in no patched .jar / .bat files
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 12-09-2016, 09:50 PM
Almaretto's Avatar
Super Moderator
Hey,
Br
Benedikt
.NET Framework 4.5.2 (or greater) is now required due to new features added.
It will work with Windows 7-10, you do not need to run in compatibility mode.
Old 12-10-2016, 04:51 AM
Hi,
thx for you help.
i deleted everything and installed again. -> its working now.
THX
br,
Benedikt
Old 12-10-2016, 07:06 AM
Hi,
thx for you help.
THX
br,
Benedikt
Old 01-06-2020, 01:11 PM
allanasi60 allanasi60 is offline
Mein Auto:
Hello think i have same problem.
ESysLauncherPROSetup_2.8.1_Build_155
E-Sys_Setup-3.30.1-49938
windows 10 1909 OS Build 18363.535
E-sys launcer i installed correclty , and its starting to load E-sys , but not only the E-sys showing , and then closing notginh happend.
when i start E-sys without Launcer no problems.
I have same combo in my old laptop and its working good.
Sorry my bad english
Allan
Old 01-06-2020, 01:50 PM
Allan
Did you attempt at some time to change System Date back in order to rearm Launcher Premium after it's Token expired?
Old 01-07-2020, 11:22 AM
Mein Auto:
Hi, haven't changed the time of launcher .
old laptop with windows 8 in there i didn't have to change time and everything works perfectly.
If I change the date in windows 10 then it throws in advance "date incorrect or date manipuation detected " Launcer pro writing this
i want all program in new laptop
Old 01-07-2020, 11:45 AM
Once you change System Date, Launcher has built in Date Manipulation protection, and it wont run. Only solution I have seen that works is a fresh install of Windows.
Old 01-07-2020, 01:48 PM
Mein Auto:
Now i find ESysLauncherPROSetup_2.8.2_Build_162
launcer writing Username BFU_XoDe valid until tuesday 21.april 2020 , i click launch now , startinh loading E-sys 3.30 .... and close again
Old 01-07-2020, 01:54 PM
It will not work once you manipulate system date, even if you chnage date back. Get Launcher PRO 3.x or E-SysX.
Old 03-04-2020, 04:23 PM
alien2108 alien2108 is offline
Mein Auto: F11 M550xD
I have same issue on Win 10 1909. Downloaded the official version PRO 2.8.2 with token from TokenMaster and it just quits with "an error occured while trying to start E-Sys....". Running E-Sys directly works without problem.
Clean Win 10 Pro x64, no date manipulations....
bmw, coding, e-sys, f11, premium launcher
