It's Been A While - Bimmerfest - BMW Forums
Old 12-26-2016, 10:25 AM
AlmostAnExpert AlmostAnExpert is offline
Mein Auto: 2007 BMW 530i
It's Been A While
Hello everyone!
Here is my situation, I've been away from home for almost two years and my 2007 BMW 530i has been sitting for nearly 1.5 years after traveling 200,000 miles in its beautiful life. I'm coming home soon and I was wondering what all should I replace? The battery was recently replaced and the car started and moves, but has an "odd" idle, high and low. My guess was the idle control valve, if so that's an easy fix.
I've thought of flushing all fluids (from the radiator to the brakes), tires, filters, belts, water pump, and spark plugs. It has 200K miles in it and I'm pretty sure the inside of the engine has to look pretty black. To what extent should I clean it, if any?
Any help would be great. This is my first BMW and I've looked up a lot of "how to" videos, but nothing works as well as asking the people who know about the car directly. Thank you all.
Old 12-26-2016, 10:32 AM
toga94m toga94m is offline
Mein Auto: 2006 530xiT
Assuming this is happening while the car is in park... try turning off the heat/ac/fan and see if that makes a difference. Could be your air conditioning cycling on and off, which requests a higher idle speed to power the load. Does it happen with every start, or just one time? If the car warms up and drives around a while, then parks and restarts when warm, does it still have the odd idle? Is the fuel still the 2-year-old fuel that's been sitting in the tank the whole time? Full or empty tank?
2006 530xiT 6MT - 150k miles - 3rd owner - sport & cold packages
Old 12-26-2016, 10:43 AM
I'm fairly certain it's the same fuel. My grandma drove it around for awhile, then the registration went out, so it's sat there. I'll have to ask her to test all these out and get back with me. I won't be home for another three months, I'm just wanting to see where I'm at and what needs to be done.
Old 12-26-2016, 11:25 AM
twh twh is offline
Mein Auto: '06 530xi 6sp
Just drive the car for a while and then decide. If it starts then the gas hasn't gone bad or at least not too bad. Throw in some fuel injector clearer for the next couple tanks.
Old 12-26-2016, 07:02 PM
Okay, I'll let them know. Thanks.
Old 12-27-2016, 06:25 AM
DanielFD's Avatar
DanielFD DanielFD is offline
Mein Auto: 2007 BMW 550i
No idle control valve on your N52 motor. Throttle Body doens't even operate the car when running. Valvetronic takes care of that. My bet is on fuel injectors. They will probably need a good cleaning. Also driving a misfiring car to try and clear it up wont work as your car will turn off fuel to cylinders that are misfiring constantly.
2007 BMW 550i - Eibach Pro-Kit on M-Sport Shocks - Kumho PS91 Tires - High Gloss Black Grill and Trim - Brushed Chrome Exhaust Tips - Euro Taillights - Debadge - Weisslicht Angel Eyes, 5000K Interior LEDs, and BMW License Plate LEDs - Osram Night Breaker D1S Bulbs - MULF2 and 6FL Retrofit - PIP Video Module Retrofit with Screen Mirroring and Rear Cam
Old 12-27-2016, 06:12 PM
Interesting. I told my family to put some new fuel and injector cleaner in it yesterday, so hopefully, when they get around to it, that'll help it out. Thank you.
Old 12-28-2016, 12:36 AM
DanielFD's Avatar
I meant more in the lines of removing them and cleaning them in a fuel injector cleaning machine. If your pretty lucky just some injector cleaner might work, worth a try.
Old 12-28-2016, 04:38 AM
Oh wow, well that is good to know. Not what I was thinking at all lol but yeah, I'll keep that in mind. Thanks
Old 12-28-2016, 06:51 PM
eburnz's Avatar
eburnz eburnz is offline
30FF <3
Mein Auto: 2007 335i sport
its better to also drive it hard when u got the cleaner in the system to help clean and burn off gunk etc....
2007 BMW 335i Sport
Gone but not forgotten:
2007 550i SMG AMRTuned (Prod. 10/2006)
2004 BMW 530i (Prod: 7/2004)
2001 BMW 525i (Prod: 10/2000)
"Call it what you want, it's a BMW"
Can you beat this?
Old 12-28-2016, 07:26 PM
Yeah, that's what I was telling them.
200.000 miles, 2007, 530i, changing, clean, diy, fix, maintenance, replace, service, troubleshooting, tune up
