730d conversion to 750d? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - F01 / F02 / F03 / F04 (2008 - 2015)
The 5th generation F01/F02/F03/F04 BMW 7 Series flagship forum. The redesigned 7 series leads off the BMW Fxx chassis code, offering an 8 speed automatic transmission and all turbocharged engine options.
Old 04-22-2017, 11:52 AM
besse besse is offline
Mein Auto: 730d-f01 745i-e65 M5-e60
what do you need to convert a 730d 2009 (245hp) with singel turbo to a 750d 2013-2015 (381hp)
Do i need to change any thing inside of the engine or just swap turbos, exhaust, and ECU/ or update standard ECU with 750d tune?
what i can understand so is the engine the same N57 3 liter diesel. In that case i feel that the 730d is a choked version of the real potential of the N57 engine.
Old 04-23-2017, 02:43 AM
Hattat Hattat is offline
Mein Auto: F02 740li
N57D30Ox has 1800 bar fuel pressure, while N57D30Tx has 2000 bar fuel pressure. N57D30Ox uses single turbocharger, while N57D30Tx uses 2 turbochargers, and N57S uses 3 turbochargers of varying size.
Bore x stroke: 84 mm (3.3 in) x 90 mm (3.5 in)
I believe the management system is completely different as well.
Old 04-23-2017, 09:47 PM
Yep i did find that on wiki too... thanks...although doesn't help much
730d, 740d, 750d, power, tune, turbo, upgrade
