E60 winter wheels on F10? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Tires, Wheels, Brakes & Suspension
Discuss everything about wheels, tires, suspension and brakes for your BMW.
Forum sponsored by: Discount Tire
Old 12-29-2019, 01:41 PM
_dav3d_ _dav3d_ is offline
Mein Auto: 2014 528i X-drive
Hello,
As mentioned in a previous thread I recently got into a 2014 528i x-drive after my 2008 528xi was totaled.
I have a set of BMW style 138 17" wheels with winter tires mounted (225/50/R-17) from the '08 car. ('08 had 18" wheels but bought smaller wheel / higher section tire for winter use). Tires are almost brand new.
As far I can tell online it looks like same bolt pattern and axle diameter as the '08 wheels but the rims have 13mm more offset than the wheels on the car now.
Anyone have any info they can share? Recommendations? Would it be safe to chuck them on the car and test them out?
TIA
Old 12-29-2019, 02:44 PM
spazzz spazzz is offline
Mein Auto: 08 535XI,XHP/MHD
Are you saying the offsets are the same to?
If they spin and don't rub there isn't a problem
There will be an inch smaller diameter which will make your speedometer even more wack than it already is.
Old 12-29-2019, 03:31 PM
The smaller wheel diameter is offset by higher section tires, the diameter at the road is the same with both 17" and 18" wheels.
But yes, the offset is the one thing that is different: -13mm with the E60 Type 138 wheels compared to the wheels currently on the car.
Thanks it sounds like it's at least OK to try them out,
Old 12-30-2019, 09:55 AM
CameronR CameronR is offline
Mein Auto: 2004 530i silver over bei
E60 wheels have 20mm offset. Your car has even more offset. They will poke out but might work, look for contact on the outer edge of fenders.
Sent from my LG-H915 using Tapatalk
Old 12-30-2019, 12:47 PM
wcr3d wcr3d is offline
Mein Auto: 2013 535iX M Sport
It's the wheel that has an offset, not the car.
Xdrives have the need for higher offset than RWD.
Assuming standard width the E60 needs 43, the F10 needs 33.
As width changes so does offset requirement.
These numbers vary a little as do peoples definition of "Aggressive" .
Here is a website with a calculator to play around with numbers.
www.willtheyfit.com
Old 12-30-2019, 06:12 PM
Looks like it should work, more of a difference than I thought though.
Old 12-30-2019, 07:21 PM
Due to dropping offset and width.
Old 12-30-2019, 09:11 PM
Jay Arras's Avatar
Jay Arras Jay Arras is offline
Casual Fanatic
Mein Auto: 2007 530xi 6 speed manual
Wrong, wrong, wrong, wrong, wrong, wrong, wrong, wrong! Don't make blanket statements like that! Some may, yes, but AWD cars have larger offsets and ETs for OEM wheels for E60s range all over the map.
2007 530xi, Black Metallic Sapphire, 6 speed manual, Sport package, Cold Weather Package, Premium Package, Premium Sound Package, Sirius Satellite Radio, MTech front bumper, Replica Style 166 wheels
Old 12-30-2019, 09:21 PM
If they dont rub inside, use them for winter. What the hell, why not.
You already have snows on them. Save your other tires for a minute.
You might want to throw 1 in the trunk for a spare.
