Waze vs. BMW speedo - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > G30 (2017 - Current)
The next generation 5 Series, chassis code G30, arrives at dealers in February 2017. Looking like a scaled down 7 Series and riding on the CLAR platform, the new 5 Series will have a focus on lightweight and sporty performance. Engines options will come from BMW's new B family for the 530 and 540 and a turbocharged V8 for the M550i. Read more about the 2017 5 Series
Old 10-18-2019, 08:59 AM
BradN BradN is offline
Mein Auto: 2018 530e xDrive
Waze vs. BMW speedo
This may be a silly question, as I would imagine the factory speedometer is accurate assuming the wheel/tire configuration didn't change, but I notice when using waze at highway speeds, it shows 3-4 mph slower than the speedo. Which one is likely the most accurate?
Thx!
2018 530e xDrive M sport Black Sapphire - Current
2015 535i xDrive Alpine White - Gone
2012 535i xDrive Graphite - Gone
If at first you don't succeed, maybe skydiving isn't for you!
Old 10-18-2019, 09:02 AM
DonnieZ DonnieZ is offline
Mein Auto: 2016 535ix Luxury Line
Waze vs. BMW speedo
Waze. All of my German cars, going back to my 1997 VW Jetta TDI, always read about 3-4 mph faster than actual.
Sent from my iPhone using Tapatalk
Old 10-18-2019, 01:42 PM
540 M-Sport's Avatar
540 M-Sport 540 M-Sport is offline
Mein Auto: M550i, 540M-Sport, Scud
Agreed, Waze is going to be plus or minus 1 mph. BMW speedos are notoriously optimistic. It is a percentage off....so the mph is off more as you drive faster.
If you know someone with some hacking skills, you can adjust the percentage back in the ECU. I had this done on my E39 a few years ago. He showed me the code...BMW actually has an additive of inaccuracy built in intentionally! So he just dialed it back. They've done it this way for 20+ years. I would assume this adds additional miles than actual on the car as well.
It's stupid really. I rent cars all the time and the Japanese cars are right on the money.
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, Eibach front and rear anti-roll bars, M5 rear traction rods, H&R 15mm wheel spacers, ST X (KW) coilovers, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, Zimmerman rotors, Dinan Stage 1 software, USA Spec Ipod/Iphone integration.
Old 10-18-2019, 01:52 PM
Doug Huffman's Avatar
Nuclear engineer
Tradition has it that the German Standards Institute Deutsches Institut für Normung - DIN - required that one traveling at the indicated speed limit not be liable to a citation for speeding.
The EU / ECE standards are different. See the Wikipedia article Speedometer
Old 10-18-2019, 02:49 PM
Markst Markst is offline
Mein Auto: BMW 5
The speedometer inaccuracy does not transfer to the odometer. A more precise counter is used for that.
Old 10-18-2019, 02:50 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Mein Auto: 2006 X5 4.4/2013 650ix GC
Thx!
Ditto everyone above. Your speedometer is calibrated according to the European regulation: UN ECE Regulation 39.
You can google the above for all the fine print of the regulation.
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 10-18-2019, 07:21 PM
quackbury's Avatar
quackbury quackbury is offline
///Monkeyazz Duck
Mein Auto: 540i; 428 GC; 340i 6MT
The above answers are correct, and I for one am grateful. My 540 is so darn quiet, and the speed builds so effortlessly, that it's easy to find myself going 10 mph quicker than planned. I have my iDrive Speed Alert set to 85 mph for that purpose. And on long trips I use cruise control a lot - setting the system to 82 equals a real world speed of 79, per Waze. That's kept me out of trouble.
Current BMW's:
2017 540i MSport
2016 428 GC MSport
Prior BMW's
2018 340i RWD 6MT MSport
2015 X1 35i xDrive
2015 X1 28i xDrive
2014 535i MSport
2014 328i SportWagon
2011 535ix MSport
2011 X5 35D
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
2003 540iA M-Technic
Old 10-19-2019, 01:58 AM
nrh1703 nrh1703 is offline
Mein Auto: VW Passat
Depending on fitted options it's handy that you can adjust the speed limit adjustment, i.e. the cruise speed or limiter speed can be automatically set to a value higer or lower than the detected speed limit. I've got mine set to +4mph which takes into account the speedo under reading plus a little. This isn't via coding, just in settings;
My Vehicle > Vehicle settings > Speed Limit Assist > Adjust suggestion
Old 10-19-2019, 12:12 PM
n1das n1das is offline
Mein Auto: 14 535d Xdrive, 12 X5 35d
Internally, the speedometer is accurate with stock rims and tires. The indicated speed is biased slightly high by design to comply with the UN ECE regulation which states that a speedometer can never under-report the true speed of the vehicle for range of rim and tire sizes the vehicle is designed for. The speedometer is allowed read dead-on or high, never low. The indicated speed reads slightly high by design.
My VW TDIs I owned years ago were like this too.
Sent from my XP8800 using Tapatalk
David Sterrett, N1DAS
2014 F10 535d Xdrive M-Sport
2012 E70 X5 35d
Why DIESEL is better: (from wxmanCCM)
PM - https://sites.google.com/view/lmarzccm/home
Air Toxics - https://sites.google.com/view/loren-marz-ccm/home
Ozone Precursors - https://sites.google.com/view/lorenmarz-ccm/home
General - https://sites.google.com/view/emissions-general/home
Old 10-20-2019, 02:47 AM
dephead2004 dephead2004 is offline
Mein Auto: E39 E36 E91LCI G30
I work on the basis of adding 10% to get the true reading. Never been caught yet
Old 10-21-2019, 07:42 AM
nlaak nlaak is offline
Mein Auto:
Thx!
My M5 is off by < 2 MPH from 25MPH to 90MPH (which is as far as I tested it) when compared to my phone. Generally cars do read higher on the speedo than in reality, because if they did the opposite the manufacturer could be liable for you getting a speeding ticket.
Old 10-22-2019, 09:01 AM
Interesting. Thanks for all the feedback!!
Old 10-22-2019, 05:44 PM
Glaird Glaird is offline
Glaird
Mein Auto: F10-'16 550i, F82-'18 M4
My experience, 1.5M mies, has demonstrated that every car is different in accuracy. However, I have long ago, developed an Excel spreadsheet, in increments of miles per hour, from 0 to 200, and hundredths of seconds to cover said mile at said speed. I have used that spread sheet and very accurate stop watches, over multiple mile marker distances, to rule out misplaced single markers. I did this for self protection, for the very reasons discussed in the above posts.
Since 1999, the last 5 cars that I have owned, 3 BMWs, 1 Lexus, 1 Toyota all are accurate to the mph of actual speed. Curiously, my 550, with one size larger rear tires than stock, is still accurate within 1 mph, to actual speed. (Which poses the question, how does BMW calculate speed, if the ABS teeth on the rear disks are turning slower? But, that is a discussion for a different forum category.)
Having made and retired from a career as a Software Engr., I would put far more stock in the display on the car, than some app, written by Apple. I suspect, if you read the use agreement for Waze, there will be the phrase "for entertainment" in there somewhere, to cover their butts, should someone actually depend on the app.
Old 10-22-2019, 07:43 PM
ppointer ppointer is offline
Mein Auto: '11 335i, '00 323it
Thx!
There are a few coding tools out there you can buy that will allow you to change the speedometer to register accurately. I happen to be using a Carly, but there are others. I have a dongle I connect to the OBD port that allows me to establish a wifi connection to my phone. Then I fire up the Carly app. There are probably a 100 parameters you can modify. I can also reset the ECU for a new battery when it is time for a replacement. As a multi-BMW owner, it is priceless for me.
Old 10-22-2019, 08:42 PM
WillyG WillyG is offline
Mein Auto: 1996 BMW 840ci
Waze speedometer accuracy
I have a 1996 840ci, 1990 328i, 2000 Audi A6, 2014 MBZ GLK, and 2018 VW Passat and none of them show the same as WAZE. I think it's got something to do with the satellite signal. Sometimes it'll show 1-2 miles less, other times it'll show 2-3 miles over.
Old 10-22-2019, 09:32 PM
mach250 mach250 is offline
Mein Auto: 2019 M550i
Mine has been 2-3 mph fast on both the waze app and those radar speed signs. New tires are 40 front and 35 rear and it reads spot on now, just screwed up getting soft side-walled continentals...won't get this brand again.
Old 10-23-2019, 12:03 PM
Which continentals? I have used both DW and later DWS and found the same...soft side walls. Great ride, but steering feel or precision was lacking. I would turn in, and it was like the car reacted a split second later. I got used to it, but once I switched to Michelin Pilot Sport I realized what I had been missing. Also, the DW and DWS wore rather quickly.
Old 10-23-2019, 06:39 PM
pagefault's Avatar
pagefault pagefault is offline
Mein Auto: F87 6MT
Waze's speed is based on position data that is already a couple seconds old, so it'll be less accurate for instantaneous speed (it would be useless for determining 0-60, for example).
If you're cruising at a constant speed (and you have a good GPS fix), Waze should be accurate.
HTML code is Off
