Trunk Light Does not Work - Bimmerfest - BMW Forums
Old 09-14-2018, 02:41 PM
HarryFD HarryFD is offline
Mein Auto: 2003 BMW Z4
I noticed my trunk light was not working. I checked the bulb and the fuse and they are ok. I checked for voltage at the bulb base with none found.
I read that the switch for the light in in the rear trunk latch. I removed the trunk latch and found a two wire connector (with brown wires) laying loose in the area. It appears to the be the same wire on the lamp holder.
I am unable to find where this connector plugs into. There was no area on the latch mechanism for this wire to plug into.
Does anyone have a picture showing where the connector is located or can tell me where to look?
Harry
1970 VW Sunroof Bus - "The Magic Bus"
1973.5 911T Targa - "Smokey"
2003 BMW Z4
2009 MB C300
Old 09-14-2018, 08:06 PM
Ridin'Dirty's Avatar
Ridin'Dirty Ridin'Dirty is offline
'17 X1 - Rooster Cruisin'
Mein Auto: '93 "Beemer" R100r
I take it that your latch mechanism doesn't look like this?
If you can't fix it, you don't own it.
Old 09-14-2018, 08:58 PM
Ridin' Dirty:
No. Below is the mystery connector and a shot of my mechanism installed in the trunk. The connector will not even reach the mechanism.
The latch mechanism looks like the one at ECS Tuning.
https://www.ecstuning.com/b-genuine-...k/51247840617/
Name:	Z4 2 Wire Connector in Trunk.JPG
ID:	818443   Click image for larger version
Name:	Z4 Connector new rear latch.JPG
Harry
2003 BMW Z4
2009 MB C300
Old 09-14-2018, 10:21 PM
Sorry that I can't be more help since I don't own a Z. Maybe these two pics might give you some insight. Are you sure that one of those two brown wires come directly from the trunk light? I ask because typically brown colored wires are ground wires in a BMW. Take a closer look to see if one of those two wires has a white tracer on top of the brown color.
https://www.newtis.info/tisv2/a/en/e...ghting/tyzgjh5
Old 09-16-2018, 09:31 PM
Ridin' Dirty:
This afternoon I had some time to do some testing with my voltmeter. With the trunk lid open, I have 12 volts on one side of light. The ground side is open. When I connect the ground side of the light to the negative terminal of the battery, the light illuminates. This is tells me that my ground is missing.
Looking at the wiring diagram, it looks like the trunk switch switches the ground for the light.
I did some more testing. It appears the wire from terminal 3 of the latch connector to the light does not have continuity. I am thinking the area that flexes between the body and trunk lid has a broken wire. When I have some time, I will look into this.
Thanks for the drawing.
Can I download a full set of electrical diagrams from this site? Do I need to pay?
Harry
2003 BMW Z4
2009 MB C300
Old 09-16-2018, 09:51 PM
Originally Posted by HarryFD View Post
Ridin' Dirty:
Basically, that site is a "read only" with no provision to easily download specific articles. When I find a drawing or bit of text that I want to save, I take a "screenshot" (Print Screen/SysRq button on my keyboard) then paste it into a image viewer (IrfanView is my fav) where I can crop it as necessary, then save as a JPG in a folder for future reference.
FYI: I then use a free image hosting site (ImgBB.com) to post a link to the JPG, instead of only just a little thumbnail, in the thread that I'm responding to.
Glad to hear that the info was useful with your efforts to troubleshoot the problem.
Old 09-17-2018, 10:19 PM
I removed the flex connector between the trunk lid and the body. I found the brown with yellow stripe wire which provides the ground for the light was broken. Soldered in a splice and all is working again.
Thanks to all who helped!
Harry
2003 BMW Z4
2009 MB C300
