Trans program - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - E23 / E32 (1977 - 1994)
Old 06-14-2018, 05:25 PM
mrvoodoochild43 mrvoodoochild43 is offline
Mein Auto: '90 BMW 750il
Trans program
My car starts but it reads check control and TRANS PROGRAM its not shifting gears....help me pls
Sent from my LGMP260 using Tapatalk
Old 06-14-2018, 05:28 PM
New cat
What it do this Will from Fort Worth texas how y'all doing hope all is well on y'all ends
Old 06-14-2018, 10:47 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Welcome to Bimmerfest! I merged your two threads in the New Member Introduction forum, and moved them to the E23/E32 forum (7 Series, 1977-1994) where you should get some help.
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 07-21-2018, 11:06 AM
BEEMVEE_Naut BEEMVEE_Naut is offline
Mein Auto: 98750il e38 BLACK widow
ADVICE on possible causes 4hp24eh by ZF
Trans program message says that your car is in LIMP HOME MODE ///or nearest repair place you could trust...IT does that so you do not do more damage to the vehicle....Most likely the issue will be with one of the solenoids DEFECTIVE////short or OPEN electricaly or the speed sensor (you only have 1 in your 750il that year) non functioning or signal from it is not detected by trany control unit...It has been few months now,,has it been fixed yet??? Your tranny is 4hp24EH,made by ZF in Germany...Very solid unit used by multiple companies and HIGH-END models(Range rovers,JAGs,bimmers,Audis etc...If cared for properly,,,, they will go for even over a million miles without rebuilds...I,m seldom here,,,,,if you need help still,,send me an email to
[email protected],,,,,Im not a bussin,,or dealer or have any profit/money
interest to help you...subject should have your car model and year and transmission help in it so i do not delete it without reading it...Good luck,,,,,,,,,
Old 10-06-2018, 07:09 PM
motohunter4's Avatar
motohunter4 motohunter4 is offline
Gearhead
Mein Auto: 85 735i Euro, 08 550i/6
It is usually a voltage issue. Check your output with the engine running. If It's not showing 13.5 or higher replace the voltage regulator or alternator.
Sent from my LGLS755 using Tapatalk
Old 06-23-2019, 09:24 AM
Mines said the same then it went in limp mode..I had to replace my tranny
Sent from my LG-M430 using Tapatalk
Old 06-23-2019, 09:25 AM
I ordered my tranny for $750 off ebay and multistate charged me 700 to put it in
