E84 engine air filter replacement - Bimmerfest - BMW Forums
Old 11-16-2019, 02:26 AM
Jbranco Jbranco is offline
Mein Auto:
Hi there, I recently got myself a X1 2012 and I wanted to replace its engine air filter however, I am not able to locate it based on the first glance. Before i start to open up things just wanted to check with you guys if the mark section is where the engine air filter is located for a 2012 x1? And if you recommend OEM filter or any brand in particular?
Old 11-16-2019, 12:39 PM
stonex1's Avatar
stonex1 stonex1 is offline
Mein Auto: 13' X1 35i
That's the spot!
I usually order a Mahle off of Amazon.
2013 X1
MinGrey,Xenon,HK,PwrSeats,Sirius,XLine,Nav
Old 11-17-2019, 08:08 PM
sayemthree's Avatar
sayemthree sayemthree is offline
Mein Auto: 2008 M3
Google BMW X one air filter replacement I believe there is a YouTube video on it
For Sale 2014 BMW X1 xDrive2.8i 64,xxx miles, Le Mans Blue Metallic, Sand Beige Leather, warranty until 4/2022 or 94,800 miles PM me
Old 11-18-2019, 01:43 PM
JimH46 JimH46 is offline
Mein Auto: 2014 X1 xDrive28i
Right spot, but that cover looks slightly different than my 2014 28i Xdrive. I use RockAuto.com. I remember getting a Mann filter last time.
Old 11-18-2019, 07:28 PM
sayemthree's Avatar
Mein Auto: 2008 M3
good catch. is it an aftermarket filter ?
Old 11-19-2019, 09:27 AM
Yes.
Old 11-21-2019, 08:55 AM
dooferorg dooferorg is offline
Mein Auto: 2013 BMW X1
Yea, it's clips around it but you'll likely want to undo the bolts of the part that holds it to the chassis so you can manipulate it to get the housing/shroud apart. Good time to check to see if there's any debris in there - I shop-vac'd mine out and wiped with damp paper towel before reassembly.
