What did you do to your E85/E86 today? - Page 3 - Bimmerfest - BMW Forums
Old 01-26-2018, 02:36 PM
golferguy golferguy is offline
Mein Auto: 2008 E85 Z4 M
I installed a Grom Audio iPhone adapter and Bluetooth dongle to mine. Yea for steering wheel controls and Song/Artist/Album text on the screen!
Grom Audio USB3
2008 Black Sapphire Metallic/Imola Red ///M Roadster 6sp Manual
2012 Vermilion Red/Oyster 128i Convertible Auto
Old 01-30-2018, 06:07 AM
danergo danergo is offline
Mein Auto: E85
Mods for seats
I have just confirmed to modify my seats to be able to ventillate.
It will cool me on a hot sunny day with opened roofs. Can't wait to have it
All parts will be original genuine BMW
Old 03-02-2018, 08:11 PM
northernbassist northernbassist is offline
Mein Auto: 2003 Z4
Replaced the battery. Warm enough to drive all the way home with the top down.
Old 03-05-2018, 09:31 PM
jborchel jborchel is offline
Mein Auto: Porsche Boxster
Originally Posted by David moffat View Post
I fixed my sticky steering on my 2003 z4 by moving the adjuster ring on the eps motor.
Sent from my SM-J510FN using Bimmerfest mobile app
How has it worked out? Did you do it yourself? How long did it take? Any advice?
Old 04-10-2018, 06:49 PM
Looking-2-win Looking-2-win is offline
Mein Auto: Isuzu Truck
Different phone mount project
Well, since I got the 'broadcast-thing' to play music from my phone thru the car's radio I've wanted to change the phone mount that clips to the air vent. I've been missing the plastic screw cover from the right side of the transmission tunnel so figured 'why not'...
I got a steel bracket from home depot & went to work on it. I cut & bent till I got what would work like I wanted. I then got some 'heat-shrink' rubber tubing to encase the steel. I trimmed down a rubber table-leg boot to better fill the depth of the screw hole. Added some soft foam rubber padding pieces to help further stabilize it against the tunnel surface. Well, it's very handy and not in my way plus I'm not now worried the phone mount might break the car's air vent piece.
Old 04-10-2018, 07:49 PM
vuwebster vuwebster is offline
Muztang63
Mein Auto: 2007 BMW Z4 Roadster
Showing the "Z" some love!
I waxed my Z4 today............and she liked it!
Old 06-03-2018, 10:20 PM
gpraceman gpraceman is offline
Mein Auto: '06 Z4 ///M Roadster
My windshield trim was all cracked and the cowling was cracked and crumbling. I finally got the parts in hand and replaced them. The hardest part was removing the wiper arms and dealing with the screw in type plastic rivets. If you do the cowl replacement, don't order the refresh kit from ECS. Just order the cowl and then some of the push in type of rivets.
ID:	799468   Click image for larger version
ID:	799470   Click image for larger version
ID:	799472   Click image for larger version
2006 Z4 ///M Roadster - Interlagos Blue/Beige
Old 01-11-2019, 09:37 AM
Cvaria's Avatar
Cvaria Cvaria is offline
Mein Auto: 2003 Z4 ; 2002 Wrangler;
Got it back after madness and expansion tank failure....
Long story but, the water pump began making a loud ticking noise and I had no idea "what" was actually going on and in my present condition..... I am not trusting myself to wrench (post motorcycle accident mental issues)....
I got the car back after having to have the water pump replaced (same one i replaced years ago) and a ne gasket putvaroubd the oil filter housing. Both were a total of about 1500.
As soon as I got it back I noticed the coolant light coming on. I figured it was a temporary thing because they had messed with the coolant level... it kept coming on briefly and then going off after the initial start ups in the morning. It bothered me and I figured that they may have tapped the expansion tank while doing the fixes...
It kept up so I trusted my gut and had the expansion tank inspected and eventually replaced. Suck but, I'd rather spend a few bucks to fix the expansion tank versus a few thousand on s new car or engine work...
Done...
Madness attached... about 3 weeks between the original and the expansion tank madness
ID:	835611   Click image for larger version
ID:	835613   Click image for larger version
I like my 2003 Z4 2.5i... but love my smelly old rusty 2002 Wrangler SE more... no more motorcycles... i lived through that phase, luckily
Old 01-11-2019, 09:38 PM
Andyz4 Andyz4 is offline
Mein Auto: 2006 Z4 3.0si
I did a track event last weekend at Sebring and pretty much wore out a set of brake pads. Also boiled the fluid as it hadn't been yet changed from previous owner. Planning a mild upgrade this weekend to Hawk pads, stainless brake lines and fresh fluid.
Old 01-12-2019, 05:10 AM
Cvaria's Avatar
Do tell.
Part numbers and such please. I may be a Guinea pig with you.
Old 01-22-2019, 02:15 AM
David moffat David moffat is offline
Mein Auto: z4 2003 2.5 auto
yes did it myself
bit tricky working upside down though. the two bolts may be torq or Allen keyed. What ever you do mark the flanges with a felt tip pen and move 10mm a time. l also added a long grease nipple and added SILICON grease. Use only this and not a normal grease as it reacts with the plastic internals.
Sent from my SM-G570F using Bimmerfest mobile app
Old 01-22-2019, 04:40 PM
kptools kptools is offline
Kirk
Mein Auto: cr-x
Nothing too special. Just new all weather mats. And some mounts for my new GoPro camera. Taking the zed to the skatepark!. 58 and still skate! and Drive!
Old 01-22-2019, 05:59 PM
Derekz4 Derekz4 is offline
Mein Auto: Z4
Cool stuff! Google Sadlands to see the guys I used to skate with back in the day.
Old 01-22-2019, 06:27 PM
Kirk
Mein Auto: cr-x
Cool videos. I subscribed and will watch more. Here is me with my friends about 10 years earlier.
Old 01-22-2019, 06:40 PM
Mein Auto: Z4
Some of those Sadland videos you should see the likes of Lester Kasai, Lance Mountain, Neil Blender, Beau Brown and other pro skaters.
Old 01-22-2019, 06:57 PM
Mein Auto: Z4
And just to stay on topic, I paid the shop I use to change out the water pump and thermostat housing last weekend for the sum of $650. I just didn't want to have to deal with jacking the motor up to free the pump.
Old 11-12-2019, 01:42 AM
Cvaria's Avatar
i just upped the radio in my old Z4. pioneer AVH-3300NEX with parking brake bypass, Axxess ASWC-1, and a metra goods (99-9303/ 70-9003 / 40-EU10)
will be swapping vents to all black ones and ditching the gray ones. already ordered the black center vent with sliver highlights. the two side vent/cup holder housings, along with adding flush mount usb ports to the Metra 99-9303 hardware.
Old 11-12-2019, 01:43 PM
rmjames007 rmjames007 is offline
Mein Auto: 2009 135i
What did you do with the speakers?
Old 11-12-2019, 01:48 PM
Cvaria's Avatar
All stock.
Old 11-16-2019, 07:07 PM
Cvaria's Avatar
Changed out the failed wiper fluid pump.
Used: URO Parts 1J5955651 Washer Pump
https://www.amazon.com/dp/B0066TLNT6..._RWk0Db2SV6F9T
I can't substantiate this but, it seems that rain-x bug remover caused the pumps on my z4 and on my jeep to fail as it is the only common element in both failures that were contemporaneous
The jeep pump was replace recently too.
https://www.jeepforum.com/forum/f9/r...4374975?page=2
Fixed:
ID:	872359   Click image for larger version
ID:	872361   Click image for larger version
ID:	872363   Click image for larger version
ID:	872367   Click image for larger version
ID:	872371   Click image for larger version
Old 11-25-2019, 12:26 AM
Cvaria's Avatar
Swapping of vents.
This has been an ongoing thing since the AVH-3300 Install. Converting all the grey front vents over to black ones to better match and camouflage the AVH-3300 and the metra faceplate.
Found all the vents on ebay. I had to match the vent tabs on the side vent/holder to the z4m center vent's adjustment tabs with chrome inserts.
The last hurtle I need to vault is the passenger side cup holder "lid" (the outside cover with the little cup on it.) It needs to be swapped out for a black one. The drives side vent/cup holder came complete but, the passenger side was not complete and was broken long ago. I oreded URO replacement long ago and included that fix in the upgrade.
ID:	873251   Click image for larger version
ID:	873253   Click image for larger version
ID:	873257   Click image for larger version
ID:	873259   Click image for larger version
ID:	873263   Click image for larger version
ID:	873265   Click image for larger version
ID:	873267   Click image for larger version
Old 11-28-2019, 04:59 PM
52silverfox 52silverfox is offline
52Silverfox
Mein Auto: 03 Z4 Roadster; manual
Changed out spark plugs & points Tuesday. About $ 200. total. No problems.
52Silverfox
