Drove an M3 for the first time - Page 2 - Bimmerfest - BMW Forums
E46 M3 (2001-2006)
Old 05-30-2005, 05:07 PM
bimmerguy's Avatar
bimmerguy bimmerguy is offline
Mein Auto: BMW
Originally Posted by Nick325xiT 5spd
The M3 got that rack back when the regular E46 was ALSO 3.5 turns lock to lock. The CSL rack is only very slightly more direct, and most people who have it report that they can't tell the difference.
The reason they left it in the E46 M3 is simple:
The M3 never got the "Ultimate Parking Machine" rack, so there was no real need to change it. Again, I also suspect that the Compact rack doesn't fit.
Nick, have you tried the ZCP yet?
I test drove it and the steering felt better than an 04 with 19" rims. It was more direct and had better feedback all around. I did not care for the steering wheel itself though.
Old 05-30-2005, 05:32 PM
Nick325xiT 5spd's Avatar
Nick325xiT 5spd Nick325xiT 5spd is offline
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd Send a message via Yahoo to Nick325xiT 5spd
Mein Auto: M3 & 323i/999 KP
Nope. The problem is that there are so many different variables, that the comparison is pretty meaningless. It's amazing how quickly BMW suspension bushings get sloppy, and this will have a pretty dramatic effect on perceived feel.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed
2002 BMW M3 Alpinweiß/Black
1999 323i KP/GTS2 Alpinweiß
1990 325is Brilliantrot/Tan
1989 325is S50B30US Alpinweiß/Black
1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
Old 05-30-2005, 06:43 PM
bimmerguy's Avatar
Mein Auto: BMW
The 04 was new with under 100 miles on it.
Old 05-31-2005, 09:10 PM
LinkF1 LinkF1 is offline
Mein Auto: '16 M2
What are you talking about? And what are you comparing this sloppyness to? Every BMW I have driven has felt the same with 10000 miles on the suspension as the day the suspension was installed.
Old 05-31-2005, 09:19 PM
Then you can't feel the car, or you're deceiving yourself. Plain and simple.
Shock dyno testing shows that OEM M3 shocks lose 50% of their damping in 10,000 miles. And that's street driving.
I have yet to find a set of OEM control arm bushings that don't start getting sloppy within 5K. My rear trailing arm bushings TORE at 15,000 miles.
Old 06-01-2005, 08:30 AM
dawgbone dawgbone is offline
Mein Auto:
Would that be under track use???
The suspension has gotten pretty mooshy at about 13k..And a set of coil overs are being heavily considered in the very near future...But I do think that the car has gained better traction with suspension wear, but with entirely too much body roll in slow hard corners, for my taste...
Old 06-01-2005, 12:14 PM
Mein Auto: '16 M2
Show me a Shock Dyno of it then. You cant just spout statistics without proof.
Old 06-01-2005, 12:17 PM
I'll see if I can get a copy, but frankly, I don't particularly care what you think. The fact that you think the suspension doesn't wear in a BMW is proof enough that you aren't sensitive enough to the way the car drives for it to matter to you.
Old 06-01-2005, 12:24 PM
bren's Avatar
bren bren is offline
///Mpty pockets
Mein Auto: wankermatic
He's not lying. I believe GC has the dyno chart somewhere on their website.
Old 06-01-2005, 12:36 PM
Yes, the RTABs tore so quickly because of track use. They will wear out relatively quickly with a moderately aggressive driver, however. More to the point, the stock ones flex a lot when new.
Old 06-01-2005, 04:56 PM
bimmerguy's Avatar
Mein Auto: BMW
Wow.... thats not good, what kind of shocks do they use?
Old 06-01-2005, 05:00 PM
Sachs-Boge. One rumor that I've heard is that it isn't their fault, though. This rumor states that BMW insisted on using an extremely low-grade shock outside of its specified capacity.
Old 06-01-2005, 05:12 PM
bmw325 bmw325 is offline
Mein Auto: 528i
INteresting. For a regular sport-suspension 3 series, what brand of shock absorber would you recommend to get a factory-like ride but w/ better durability?
Old 06-01-2005, 05:18 PM
Konis. Preferably top adjustable rears.
It's best, actually, if you get double adjustable Konis. The S/As have less compression damping than stock, and it's nice to be able to adjust that to where you like it.
Old 06-01-2005, 06:36 PM
SteveT's Avatar
SteveT SteveT is offline
Mein Auto: '08 E92 M3/'11 X6 3.5
So, you make the statement that BMW has selected a shock absorber for the M3 that is under-specified for the application? You've made a lot of statements about quantitative measurements. I'm not disputing that the shocks wear nor that the stock bushings are more flexible than one would like for race applications. This is a tradeoff of comfort versus performance. To say that BMW deliberately choses to run a component out of the manufacturers range of usage is a serious charge.
SteveT
2008 E92 M3 - SSII/Fox Red
2011X6 3.5 - AW/Red/Alcantara/Leather
BMW CCA
Old 06-01-2005, 08:06 PM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
I have heard this from more than one source.
Actually the E46 M3 has higher dampening rates than most other BMWs. Sachs made a shock and BMW didn't want to go with that model of shock, so they speced a lower line model, which while it will provide the dampening rate, it will not maintain that dampening rate over a long period. Why did they do that? Not sure, but one immediately suspects cost was a factor.
It the shock running outside its spec range of dampening? Nope. But will it maintain that dampening rate? Nope. Is this a crime? Nope, more like standard practice in the auto world. Very few stock shocks are good for more than 20 - 25K miles. The old BMW standard of 80K miles was more than just about anybody else. Our Jeep Grand Cherokee stock Up Country shocks were shot in about 10 - 15K miles. A set of Bilsteins did WONDERS.
And since BMW won't warranty shocks without leakage, they are pretty safe. I guess you could pull the shocks new and put them on a shock dyno, then pull them every so often and once the dampening rate gets below x% lower than new, you could force them to give you new crappy shocks.
A set of Konis will do the trick. The top adjusting rears are nice, but for most people the basic standard single adjustable Konis will provide a similar to stock ride, with longer life.
I don't know if Bilstein makes a Touring shock for the E46 M3, but that is their stock replacement shock when it comes to dampening rate. The HD and Sport models are a good bit higher dampening rates.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 06-01-2005, 08:15 PM
SteveT's Avatar
Terry, what you are saying is fine, but it's not what Nick has said. You in fact say that the shock is within spec(provides damping rate), it just doesn't stay there. It wears out. Forgetting the superlatives, Nick is saying that it's "outside it's specified capacity."
We can be disappointed that the shocks don't last as long as we'd like, but it's another thing entirely to say that they are not up to the requirement in the first place.
SteveT
BMW CCA
Old 06-02-2005, 08:48 AM
Actually, we're saying the exact same thing. BMW picked a shock that can't handle the damping rates they wanted, apparently against Sachs' advice.
I'm not sure how one can ever say that a shock that loses a significant percentage of its damping capacity within the break in period can be called "in spec."
Old 06-02-2005, 12:05 PM
Mein Auto: '16 M2
I never said that the suspension doesn't wear... I said that after 10000 miles which is less than one year of driving the shocks feel virtually new on every BMW I have driven and every time I have replaced them you cant feel much of a difference until about 20000 miles in my experience... but it is in no way 'sloppy' as you suggest.
But that is for every other BMW... it seems that the M3 is different in this respect for some reason. Sloppyness at or before 10000 miles is very odd and seemed very much like a outlying statistic, sorry for being skeptical of a very bold statement concerning the endurance of the shocks.
Old 06-02-2005, 03:37 PM
bmwphd bmwphd is offline
Mein Auto:
Made to order M3s?
Is it possible to have an M3 made to order as it is customarily done with the other E46s?
Thanks.
Old 06-02-2005, 06:07 PM
Pinecone's Avatar
M Mad
Thanks.
Do you mean order it with the options you want(within reason)? If so yes, most of us did that.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 06-02-2005, 06:08 PM
Pinecone's Avatar
M Mad
Yeap, the newer BMWs seem to be like this. Nick had a similar experience on his 325XiT previous to his M3. But you CAN feel the difference in new shocks in the 10 - 12K miles range on E46 M3s.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 06-02-2005, 06:10 PM
Pinecone's Avatar
M Mad
Well it is a matter of perspective. Yes, they rovide the dampening rate, but not for very long. And not like older BMWs which the stock shocks were good for 80K miles or so.
If the BMW spec is X dampening rate for 10K miles, then they are fine.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 06-03-2005, 06:55 AM
Mein Auto:
The M3 seems to be pretty awesome with the standard equipment, especially with the 6 speed manual; not that I tested it but I imagine it must be something else. Because an E46 M3 would be such a treat to myself, I do not want a lot of people to drive it (such as test drive it from a dealer's lot) before I get it...
Old 06-08-2005, 06:41 PM
Ara7 Ara7 is offline
Mein Auto:
2.7 lock on ZCP
Hi,
The steering is improved on the ZCP. It's 2.7 lock to lock as opposed to 3.5 on standard M3. I have an '05 M3 ZCP and I love the steering feel. It's has a heavy feel as did my '02 530i.
Ara .
Similar Threads
Just drove an M3 6spd Cab - need clarity webguy330i 1M & M2 32 09-13-2004 11:27 AM
I Test Drove An M3!! fso_BamBam 3 Series & 4 Series 20 05-29-2004 05:27 PM
PTG Phoenix Result - ***Real Spoiler*** SteveT Motorsports, Racing & Track 8 04-22-2004 06:51 PM
FOR SALE: 1995 BMW 318Ti with M3 3.0 Motor JEFF951 Classifieds 6 07-03-2003 11:20 PM
test drove a M3.. is this fair? DINANISR3 1M & M2 12 06-06-2003 06:52 PM
