Strange OBD2 Code - U1408 - Need Help - Bimmerfest - BMW Forums
Old 02-12-2019, 11:11 AM
Emoney Mango Emoney Mango is offline
Mein Auto:
Hello,
I have a 2014 328i x Drive, 60K miles. Every since it started getting cold in New England (under 30 degrees) my check engine light has come on with code "U1408". The shop I usually go to thought it was thermostat related issues and it should be under warranty. So, I brought it to the dealer and they replaced the thermostat under warranty, but the same day it was around 15 degrees out and the CEL came back on, this time with U1408 and P0128 (low coolant temp). I brought it back to the dealer, but it was around 50 degrees that day and of course the light was no longer on . They didnt see any fault history related to the thermostat.
The CEL comes on with U1408 whenever it is cold out (under 30 degrees) and will turn off on warmer days. The oil temperature gauge also doesn't move above 160 when the light is on, and the fans run super loud when its cold out and I have the heat on. Does anyone know what this could be? Car still drives ok, don't seem to be experiencing any power limiting.
Thanks!
Old 02-13-2019, 03:47 PM
Mein Auto:
So I accessed the hidden menu in the cluster and after a 30 minute drive (mostly highway at 65mph) the oil temp and coolant temp were only around 90 degrees C (194 F). It was 40 degrees F outside. This seems to be below operating temperature and almost sounds like the thermostat is stuck open, even though it was just replaced. The CEL also shut off again. The oil temp gauge does match what the car is telling me. Any thoughts?
Old 02-14-2019, 06:32 AM
southcoastguy southcoastguy is offline
Mein Auto: 328xi
A quick google search provided this:
http://u1408.enginecodes.net/
Old 02-14-2019, 08:14 AM
Mein Auto:
I also googled it, doesn't tell me much.
Old 12-05-2019, 06:49 AM
Zux007 Zux007 is offline
Mein Auto:
Hello,
I've the same problem as you had with oil temperature. Can you tell me how did you fix it?
Thank you
Old 12-11-2019, 07:38 PM
Arcturus Arcturus is offline
Mein Auto:
Originally Posted by Emoney Mango View Post
Hello,
Thanks!
I'm having this same issue. Thermostat was replaced and same U1408 and P0128. Do you have Bimmerlink? Try measuring your lower radiator hose coolant temp with that app and see if it's weird. Mine is. I wonder if this is the issue.
Old 01-15-2020, 03:09 PM
patyoung patyoung is offline
Mein Auto: GL350
I have had similar codes and issues, what ended up being the fix?
Old 01-15-2020, 10:06 PM
Mein Auto:
For me they first replaced the MAP thermostat PN 11-53-8-635-689. That did nothing and the car still wasn't coming up to operating temp in time. The oil temp would hang at 70C on the bottom end of the gauge - even after a 30-40 min drive. I also kept getting intermittent check engine lights for P0128 and U1408 codes.
I took it back to the dealer and they replaced the auto transmission oil cooler (heat exchanger) PN 17-21-7-600-553. There is second thermostat on this part that went bad. That solved the problem. My car now comes up to operating temp after a 10 min or so drive on the highway - even in very cold weather.
I can't find it now, but if you search the internet you will see evidence that this is a somewhat common problem.
Old 01-16-2020, 03:54 PM
laser's Avatar
laser laser is offline
Mein Auto: 2007 S2000
There's an extended warranty for thermostats stuck open 10 years 120,000 miles
Laser
"sometimes you're the windshield .... sometimes you're the bug"
___________________________
2017 330i M- Sport Black Sapphire Metallic
2014 328i Mojave Metallic
2007 328i Black Sapphire Metallic
Similar Threads
Rough idle, CEL - Strange code P11B1 Powertrain BXMMMMMW X5 E70 (2007 - 2013) 9 09-13-2018 11:16 AM
Bmw e70 strange fault code Tmling76 X5 E70 (2007 - 2013) 3 06-04-2018 09:43 PM
Recently had Rotors/brakes done all 4, 3 weeks later brakes stuck/ ABS won't benspie X5 E70 (2007 - 2013) 26 03-28-2018 08:12 PM
