Ongoing air suspension issue.... - Bimmerfest - BMW Forums
Old 12-07-2019, 03:17 AM
Howquick Howquick is offline
Mein Auto:
Air suspension
Hey all, I'm posting this in the general section because I'm hoping to get a bigger audience. Can 'anyone' tell me exactly how the air suspension setup works..in detail. After having the diff in my e70 recently...I realized the rear looked a bit low. I measured it and both side are 50mm lower than spec. The air suspension system is not working. I've removed the compressor and bench tested it...all ok. I measured voltage at the 3 plugs going to the compressor, solenoid and valve block....nothing.
Any thoughts/ideas???
Old 12-07-2019, 05:03 AM
Doug Huffman's Avatar
Nuclear engineer
Here is all of the 'detail' that there is short of the technical description.
https://www.newtis.info/tisv2/a/en/e...ystems/1odeF1T
https://www.newtis.info/tisv2/a/en/e...ontrol/Xs0tfmb
Old 12-07-2019, 05:46 PM
ard ard is offline
Resident Curmudgeon
maybe working on the diff someone hosed the height sensor?
OEM is not what BMW sells
Old 12-07-2019, 06:40 PM
Mein Auto:
Thanks guys....yes...I’m beginning to think along those lines Ard.
Do you know if there is a way for me to test the sensors?
They ‘look’ fine....but who knows if they’re actually working.
Old 12-07-2019, 11:06 PM
ard ard is offline
Resident Curmudgeon
Naw. Id dig around on newtis.info...look at schematics...circuit description...see if I could make sense of the sensor function.
Looks like 3 pins...a standard potentiometer. A+B=C in terms of resistance.
HOWEVER... the links Doug posted show there are signfcant computer functions that are accessible using a BMW computer (ie ISTA, etc). Could be something simple three....
Old 12-09-2019, 05:22 AM
Mein Auto:
Fixed!
Well...I managed to get an old laptop off a mate and load Inpa. I already had the cable...as I bought it a while ago with the intention of connecting to my car.
So...I checked out the suspension and found the inferential ‘modes’.
Shipping, production, garage, energy saving, low tolmode.
It appears ‘production mode’ is active.
So...I tried toggling it off/on.
Didn’t seem to change.
So then I toggled the other modes...and I think it was ‘garage mode’ that did it...I just came good and the air bags filled up.
So very happy!!!
