Trickle Charger for 2016 428i xDrive - Bimmerfest - BMW Forums
Old 12-07-2019, 08:59 AM
Zb411 Zb411 is offline
Mein Auto:
Hi all. I am looking to purchase a trickle charger for a 2016 428i xDrive. Do you know of any that work via the cigarette lighter within the car instead of being plugged into an outlet? I know on certain versions of the vehicle the lighter cannot be used. Ideally looking for that type so I can fully wrap the car with a cover over it without any openings for the winter. If not, are they any specific versions that use an outlet that you suggest? Thanks very much for the help.
Old 12-07-2019, 09:02 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
CTEK 4.3 MUS. Your owners manual instructs to charge only via the underhood charging points.
Old 12-07-2019, 09:41 AM
dzlbimmer dzlbimmer is offline
Mein Auto: Diesel
The "cigarette lighter" power point disconnects from power after the vehicle turns off and times out. You must use the power points under the hood. You can make a permanent power lead off the charging posts that drops out near the grill.
Old 12-07-2019, 11:23 AM
chiefneil's Avatar
chiefneil chiefneil is offline
Mein Auto: 2014 335i, 2002 330i
Iím unclear how running a wire to the cigarette charger outlet doesnít require an opening while running a wire to the engine bay does?
Just run the wire under the bottom edge of the cover, through the grill, and youíre done. Versus getting a wire into the cabin would require leaving a window open a crack for bugs and moisture to get in. But either way you have to run a wire.
And yeah, as others have pointed out - using the cigarette lighter outlet isnít recommended and it shuts off anyway.
Another alternative is to skip the float charging and just juice the car up once midway through the winter. Or not worry about it at all and leave it alone until Spring.
Current Stable: 2014 335i M-Sport // 2012 X5 35i Premium // 2002 330i Sport
Out to Pasture: 2002 X5 3.0i // 1995 325i Sport
