Winter is here. I just topped off the tire pressure. - Bimmerfest - BMW Forums
Old 12-07-2019, 11:14 AM
EconoBox EconoBox is offline
Mein Auto: 2001 330i
Inflated the tires to 32F & 36R.
What pressure do you like?
2010 manual
2010 X3
2001 330i
Sold: 2001 530i
Old 12-07-2019, 11:34 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
36 & 41
Old 12-07-2019, 11:44 AM
x3brian x3brian is online now
Mein Auto: X3
What does your door say and what size tires?
We know your car is a base so wouldnít expect staggered tires and base 17Ē rims with 235/55/17 unless it got 18s.
If you have base 17s, my door sticker says 32 f and 33 r. Iíve always maintained that. Im on my third set of replacement tires. Never had issues in winter snow but always had good tread depth when winter hits since Iíve live in MD.
Old 12-07-2019, 11:46 AM
Mein Auto: X3
Originally Posted by Doug Huffman View Post
36 & 41
Show off. We know the x5 is bigger.
What size tires are you running?
Old 12-07-2019, 12:18 PM
Nuclear engineer
255/55r18
To a first approximation, tire pressure is weight on one wheel divided by footprint projected to the inner casing.
I am having a great time trying to find the actual calculation. I'm 75% through 700 pages of The Pneumatic Tire DOT HS 810 561
Old 12-07-2019, 02:56 PM
app[/url]
I have 235/55/17 so I went 32F/36R
2010 X3
2001 330i
Sold: 2001 530i
Old 12-07-2019, 03:32 PM
Mein Auto: X3
Interesting. Exactly the same tires and car and they increased rear pressure 3 pounds between 09 and 10.
I just checked my manual and says 32f and 33r.
Old 12-09-2019, 11:29 AM
DangermouseX3 DangermouseX3 is offline
Mein Auto: 2007 X3, 2008 X3
The stickers on my cars both say 32/32.
OP - what do you mean by "winter is here - topped off my tire pressure?"
07 X3 3.0Si - AT - Black with tan leatherette interior - 141k miles
08 X3 3.0Si - AT - Black with black leather interior - 121k miles
Old 12-09-2019, 01:47 PM
Cold air
volume decrease
top up
2010 X3
2001 330i
Sold: 2001 530i
Old 12-09-2019, 02:04 PM
abscate abscate is offline
Mein Auto: 2006 BMW X3... VOLVO... V
That is some sort of PVneRTed behavior..
Old 12-09-2019, 10:03 PM
Attacking Mid's Avatar
Attacking Mid Attacking Mid is offline
Mein Auto: 04 X5 3.0i, 08 X3 3.0si
I guess I try to check my tire pressures much more often than seasonally. Realistically, I probably check every 4-6 weeks. I generally run 3 psi higher that what is listed on the door sticker (for all my vehicles) - except during snowy conditions where I'll drop the pressure to the recommended pressure. In really bad conditions, I have gotten out and let air out of the tires to further improve traction. I haven't had to do that with the X-drive vehicles, but I've had to with my RWD e46 and other 2WD vehicles in slick conditions.
AM.
Old 12-10-2019, 12:46 AM
Autoputzer Autoputzer is online now
Mein Auto: 2014 535i + 2018 X3 30i
All my tires leak between a half-PSI and one PSI every two to three weeks. In the fall, with steadily falling temperatures, the pressure goes down even faster. In the spring, with steadily increasing temperatures, the pressures go down slower. Only adding about one PSI, it's no trouble to do it with a bicycle pump.
Ideally.
Old 12-10-2019, 10:49 AM
woofster woofster is online now
Mein Auto: BMW
Originally Posted by Autoputzer View Post
Ideally.
Here's an 'ideal gas LOL' for both of you!
Old 12-11-2019, 06:17 AM
Cold air
volume decrease
top up
Interesting.
Do you do the opposite in the summer?
