Removing the ugly visor warning labels - Bimmerfest - BMW Forums
Old 11-06-2014, 09:20 AM
nybhh nybhh is offline
Mein Auto: 2015 428i x-drive coupe
I was snapping pics of my Invisicord / Escort Redline install and just realized how ugly those stupid warning labels are. Has anyone tried removing them?
ID:	474399   Click image for larger version
Old 11-06-2014, 09:46 AM
KAP8's Avatar
KAP8 KAP8 is offline
Mein Auto: Alpinweiss F32
Do a search on the internet. There should be information out there. I believe there are threads in the E9x forum here as well. I think people recommend using "Goof-Off", but there may be other chemicals. They are ugly.
2015 435i ///M Sport | Alpine White | Coral Red | 19" | Auto | Cold Weather | Driver Assistance | Dynamic Handling | Lighting | Premium | Technology | M-Sport Brakes | Rear Sunshade | HK | Leather Dashboard | MPPK | MPE | Dinan Suspension | BMWCCA #409820
PCD: 10/31/2014
Old 11-06-2014, 01:35 PM
jimpal's Avatar
jimpal jimpal is offline
BMW's Since 1989
Mein Auto: 2014 328xit
There was a good deal of discussion about this on the F10 site 2-3 years ago. As I recall one or more suggestions worked well for people. Suggest you research those threads.
Old 11-06-2014, 02:50 PM
jayb328i jayb328i is offline
Mein Auto: 328i
It has been many years since I removed my label on the sun visor. After research, I used rubbing alcohol. BUT the secret is to get the label real soaked without ever touching the visor around it. This is important because the ink from the label will stain the visor. I used cotton, changed it 100 times, and kept wetting the label until it just peeled right off. But DO NOT let that wet cotton touch the surrounding visor, it will leave an ink stain from the label.
Old 11-06-2014, 03:39 PM
Hill Hill is offline
Mein Auto: Kubota & F31 diesels
If they're really firmly glued it's best to take the visors down so you can work on a bench.
Old 11-06-2014, 07:09 PM
alpinweiss alpinweiss is offline
Mein Auto: E46, E83, E90 (all MT)
Some of the sunvisor labels are glued in such a manner to thwart their removal. It can be done, but it is a lot of work.
An alternative is to order a pair of European sunvisors from one of the online merchants. They are not cheap, but they are easy to install, and look factory new.
Alpinweiß
E46, E83, E90 (all with three pedals)
F25 (missing third pedal)
BMW CCA member
Old 11-06-2014, 09:18 PM
Mein Auto: 328i
That is exactly what was the label on my sun visor. It was not removable, could not peal it off. So well glued on it was as if it was one. BUT as I describe above, the alcohol removed each label after about 20 minutes with no problem. Just read the word of caution I gave. You will need to use many cotton swabs until each area of the label comes loose--and it comes right off. The alcohol eats away the glue once the paper becomes saturated. Slow process
Old 11-07-2014, 10:33 AM
glennQNYC glennQNYC is offline
Mein Auto: 2014 M Sport 335i
Sorry to veer off topic…... But with the RADAR detector clipped to the visor, what do you do when you need to rotate the visor to the door/side?
Old 11-08-2014, 12:59 AM
rneclps rneclps is offline
Mein Auto: 330ci, x53.0i
Denatured alcohol
Old 11-08-2014, 12:37 PM
EddieB's Avatar
EddieB EddieB is offline
Mein Auto: '13 335i M-Sport 6sp
+1 That is the best way. I've used Goof Off and it is messy.
F30 Sapphire Black 335i 6MT|2PE|4AB|ZDH|5AC|LCSW|ZMM|ZPP|ZCW|ZDA|ZDB|ZTP|4 15|688 Dinan Stage 1 Suspension and Shockware ECU tune
Previously - F30 335i, E46 M3, E39 530i, E46 325i
Old 12-07-2019, 06:46 PM
x986 x986 is offline
Mein Auto: 340i
This thread has gotten kind of moldy, but I would like to dust it off in case anyone with one of today's cars has had success. They used to peel off, but this year's model seems to be too thin. I had success with a recent P-car by taking the visor off and soaking it in alcohol, but I haven't been able how to remove the BMW visor. Hopefully I'm missing something simple.
Old 12-07-2019, 07:55 PM
John in VA John in VA is offline
Mein Auto: '74 tii / E28s / '03 530i
You can check the TIS online repair manual for sunvisor removal - https://www.newtis.info/tisv2/a/en/
Another decal removal thread - https://www.2addicts.com/forums/show....php?t=1078937
___________
BMW CCA #30375 - National Capital Chapter
1974 2002tii
1986 535i
2000 328i
2003 530i
2006 330ic ZHP
2015 228i M Sport
