Vent issues - Bimmerfest - BMW Forums
Old 12-08-2019, 12:07 PM
dgjks6 dgjks6 is offline
Mein Auto: 2008 535xi
Vent issues
Here is a weird one. No hot air from passenger vents. The dash vents on the driver side warm air, passenger, cold no matter what I set it at
Any ideas?
Sent from my iPhone using Bimmerfest mobile app
Old 12-08-2019, 12:28 PM
t_mo_t t_mo_t is offline
Mein Auto: 2005 545i 6-speed
Old 12-08-2019, 01:47 PM
audiophool audiophool is offline
BMWs since '87
Mein Auto: 2008 535xi (LCI)
Check the water valve assembly. Feel the hoses coming out - they should ALL be hot when the HVAC is calling for hot. If one pipe is cool, that's your problem. The valves are supposed to be open when there is no power, and the solenoids cycle closed to pulse warm water to the heater core. If the solenoid is stuck closed you get no heat.
https://www.realoem.com/bmw/enUS/sho...diagId=64_1481
Hose 5 is supply, 2 and 3 are outlets to the heater.
Old 12-08-2019, 05:11 PM
scottalexander scottalexander is offline
Mein Auto: 2010 bmw 528i
Are you thinking this directional flow diagram is accurate below?
Name:	Z572 - direction of flow.jpg
Old 12-08-2019, 09:09 PM
BMWs since '87
^yes
Old 12-08-2019, 10:49 PM
kkontney kkontney is offline
Mein Auto: 2010 535i
Fixed on Mine
I had the same problem. cool air on the drivers side. I just replaced the water valve and now it is just as hot on the drivers side as the passenger side.
-Kyle
Old 12-09-2019, 04:55 AM
Cool. I get it now. Hot coolant to valve and the split in half for the driver and passenger. Will fix if my passengers start to complain.
Old 12-09-2019, 05:15 AM
Doug Huffman's Avatar
Nuclear engineer
HCV fail for the orifice becoming clogged by disintegrating seals in the valve that circulate through the coolant system and can cause damage wherever they might. The HCV orifices are the only 'strainers' in the system. BMW hint hint hint
Old 12-09-2019, 05:16 AM
Kurt_ Kurt_ is offline
Mein Auto: 2008 535xit
Did you scan codes? It could also be a stuck flap, there's a few in the duct work to do the splitting. A code readout would tell you if one is malfunctioning.
