BMW X5 35d 8 speed transmissions??? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners & Enthusiasts
Old 04-06-2019, 08:48 PM
Blown540 Blown540 is offline
2010 BMW X5 35d
Mein Auto: 2010 BMW X5 35d
This has been discussed in several places, but I cannot find through much searching BMW forums and even factory specs in several magazines and websites. Can someone tell me for sure, what year the BMW x5 35d changed from a 6 speed to an 8 speed transmission.
A friend call with a 2012 and even he does not know if it is a 6 speed or 8 speed transmission. Can someone help me identify for sure, before I buy and buy thinking I am getting an 8 speed transmission?
THANKS IN ADVANCE FOR ANY HELP. I AM SUPPOSED TO LOOK AT THE 2012 MONDAY AND WOULD LIKE TO KNOW HOW TO TELL? thanks, JIM IN TN
AND YES, I HAVE COUNTED THE SHIFTS ON MY 6 SPEED AND I MIGHT COULD COUNT THE 8-SPEED TOO AND WILL TRY THAT IF ALL ELSE FAILS-THANSK, JIM
Old 04-07-2019, 03:41 AM
Doug Huffman's Avatar
Nuclear engineer
YOU can search RealOEM.com by vehicle detailed description as well as by VIN-7 that many use.
Mine; GA6HP26Z. From 07/2011 part number 24 00 7 631 059
Old 04-07-2019, 07:45 AM
2010 BMW X5 35d
THANK YOU and I really appreciate the help! AND I LOVE driving my X5s and even try to drive them more than my M3 Convertible. I really appreciate the forums and the help owners give to each other-Jim in TN
Old 04-07-2019, 09:24 AM
All e70 x5 diesels have the 6 speed.
E70 gassers got the 8 speed mounted to the N55 and N63 engines, which coincided wit( the LCI. Pre LCI gassers had the N52 and N62 with the 6 speed.
All F15 X5s have the 8 speed
Sent from my iPad using Bimmerfest
Old 04-07-2019, 12:22 PM
2010 BMW X5 35d
THANK YOU very much and really appreciate your help! Jim in TN
Old 04-10-2019, 12:48 AM
SPL15 SPL15 is offline
Mein Auto: E36 M3. E46 325i, E70 35d
I think I read somewhere on the webs that European models of the 3.0d got the 8 speed 8HPxx ZF transmission, but I'm too lazy to confirm, as it does not make a difference to me, thus is not worth my time to confirm.
My 2012 E70 35d has a 6 Spd 6HP28X transmission, as casted onto the side of the transmission housing, & confirmed via the valve body design per ZF literature. All US model E70 35d's have a 6 speed ZF 6HPxx transmission, some reportedly the Gen1 6HP26x, some reportedly the Gen2 6HP28x. The "28" is the Gen2 of the 6HPxx series; the Gen1 "26" variant is the same transmission, just the gen1 version of the same transmission. There's also a 19 & 32 variant, the last two numerical digits indicate maximum torque, as well as generation. The "26" & "28" 6HPxx transmissions are what was used on the 6 Spd E70 diesel models in the US.
It is surprising that Doug's transmission is reportedly the Gen1 6HP26 model, as the Gen2 6HP28x has been reported to be found, w/ photos to confirm, on E70 35d's from as far back as 2009...
Old 04-10-2019, 02:23 PM
2010 BMW X5 35d
Thank You very much for your information. I can now check my numbers and see which model 6-speed I have. I am still receiving information that it is going to be a F15 X5 model that came out in 2014, to have a 8-speed trans behind the diesel X5. Thank You again! Jim
[SIGPIC]
Old 04-22-2019, 01:02 PM
n1das n1das is offline
Mein Auto: 14 535d Xdrive, 12 X5 35d
While I will always prefer a manual transmission, I have found the 8-speed automatic in my 535d to be one automatic that I really DO like. I like the 8-speed automatic in my 535d better than the 6-speed auto in my E70 X5 35d. I drive my cars exclusively in Sport mode.
Sent from my XP8800 using Tapatalk
David Sterrett, N1DAS
2014 F10 535d Xdrive M-Sport
2012 E70 X5 35d
Why DIESEL is better: (from wxmanCCM)
PM - https://sites.google.com/view/lmarzccm/home
Air Toxics - https://sites.google.com/view/loren-marz-ccm/home
Ozone Precursors - https://sites.google.com/view/lorenmarz-ccm/home
General - https://sites.google.com/view/emissions-general/home
Old 06-04-2019, 12:20 PM
delviacv2 delviacv2 is offline
Mein Auto: 2015 X5 35d & 2011 x5 35d
David, I just Did the xHP stage 3 flash to my transmission and it feels like a dual clutch, it shifts super fast!
2015 535d Xdrive M Sport Alpine White
Fully Deleted
DUDMD Stage 2
xHP Transmission Flash
2014 X5 50i M Sport
BM3 Stage 1
Old 06-23-2019, 11:35 PM
ard ard is offline
Resident Curmudgeon
Seems to me this tends to get laid out in the various wikipedias, on the E70, and the ZF6 & 8 transmissions...no??
OEM is not what BMW sells
Old 06-25-2019, 04:31 PM
robnitro robnitro is offline
Mein Auto: x5 35d e70 2011
Sport mode stock tune stinks in the 6hp with diesel. It keeps the revs too high and kills economy in stop and go. On my commute with the same speeds, sport was 10% worse usually.
Now with xhp, my sport is between original D and S, Tcc stays locked up longer.
Hills were changed too, no more holding high revs for a hill that could be done at 1500 even.
My D is low revving like the alpina tunes and it's solid too but now D and S don't have that huge of a spread in mpg anymore.
My only gripe with the 6hp is that 6th is too close to 5th and they didn't put a tall enough diff. [email protected] is stupid for a diesel.
Old 06-27-2019, 08:57 AM
Nyc Dito's Avatar
Nyc Dito Nyc Dito is offline
Kinda officially welcomed
Mein Auto: E70 LCI 35d
Thanks for the info. I just ordered the Bimmergeeks cable and should be doing the Xhp tune soon based on your experience and a few others i found in my searches. I've seen other tunes suggested but Xhp seems to fit what im looking for =). Now I need to find a good battery tender/charger thingy...
Then xDelete =)
E70 LCI 35d
E90 LCI 328i xDrive
E39 528i/5 Sport
E28 535is
E84 X1 35ix M package
E38 740i Sport
E39 M5 LMB/Blk
Old 06-27-2019, 02:39 PM
What other tunes did you see for our 6hp trans? Is it with something other than xhp?
I made my own custom tune but I hear stage 1 and 2 are good. 3 is not worth the stress... Shifting faster is not good for things. Slightly faster than stock is good though.. Stock is lazy for comfort.
Old 06-28-2019, 06:09 AM
Nyc Dito's Avatar
I came across "DWR", Rod Sutphin Trans Tune (I think that's the name) and I think Xhp was the only other one. I was thinking stage 1 would be good enough. I like that's its all programmable from the app, so that's a big plus for me. I'm an idiot when it comes to sending/storing files to tuners and afraid of bricking something haha
E70 LCI 35d
E90 LCI 328i xDrive
E39 528i/5 Sport
E28 535is
E38 740i Sport
E39 M5 LMB/Blk
Old 06-28-2019, 08:45 AM
alacey alacey is offline
Mein Auto: 2014 328D
I used Bimmercode to code in Sports+ in my 328d with a 8HP. I also coded in "Sport Automatic Transmission" mode (which comes with the 2TB package on Sport line or M-Sport line models), and man does this 8hp shift quickly when in Sports+ mode and the gear lever is moved to the left in sports transmission mode. I thought it was quick before I added this coding, but it is a huge difference afterwards.
On a side note, what trans temps are you guys seeing on your 8hp's? I am seeing around 200F +/- 5 degrees. Not really that high, but I am used to seeing a range of 170-175F in my diesel truck unloaded and never seen 200F even when towing my 14k lb 5th wheel.
Old 08-24-2019, 12:32 PM
2010 BMW X5 35d
Can someone tell me for sure what year the F15 BMW X5 35d was sold, just making sure again what year will have the 8 speed auto trans-THANKS again for your help! Jim
Old 08-24-2019, 03:24 PM
2014 - 2018, at least in the USA.
The last model year for the E70 X5 35d was 2013.
2012 E70 X5 35d
Old 08-24-2019, 09:31 PM
jfxogara jfxogara is offline
Mein Auto: 2011 335d, 2009 G650-GS
The Rob Sutphin tune transformed my 335d. Really smooth, rev matching, just excellent.
I previously had the XHP Stage 2, which was an improvement over stock.
35d, trans tune, xhp
Similar Threads
Complete 2018 Model Year BMW Pricing and Ordering Guides - All Models tim330i Ask-A-BMW-Dealer 7 10-09-2018 01:15 PM
E65 V12 debuts nate General BMW Questions 22 06-09-2016 01:44 AM
1998 M3 = 540i = 740i = 20K rumratt General BMW Questions 36 01-12-2007 07:26 PM
Alternative to a shorter diff? Nick325xiT 5spd 3 Series & 4 Series 28 04-05-2002 08:06 PM
