Any tips on taking apart the steering column covers? - Bimmerfest - BMW Forums
Old 04-25-2011, 02:48 PM
540 M-Sport's Avatar
540 M-Sport 540 M-Sport is offline
Mein Auto: M550i, 540M-Sport, Scud
I have a buzzing noise coming from there freeway driving on concrete pavement, and wanted to remove them and see about installing some foam tape or padding to stop the vibration.
Any tips? I removed the screws, then just pry them apart? I don't want to break anything...
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, Eibach front and rear anti-roll bars, M5 rear traction rods, H&R 15mm wheel spacers, ST X (KW) coilovers, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, Zimmerman rotors, Dinan Stage 1 software, USA Spec Ipod/Iphone integration.
Old 04-25-2011, 03:10 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Mein Auto: 2006 X5 4.4/2013 650ix GC
That's pretty much it. Undo the screw on the top & bottom, then separate the two "clam shells". I can't remember but you may have to deal with the accordian thingy on the top clamshell where it attaches to the instrument cluster...if you do...it's only a few clips that holds it to the cluster.
(screw on top clam shell)
(screw on bottom clam shell)
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 04-25-2011, 03:25 PM
JimLev JimLev is offline
And move the steering column out and down for more access.
Old 04-25-2011, 07:52 PM
Melrose Melrose is offline
Mein Auto: 540i
Whatever you do, do not try to replace the upper gaiter (boot), whose molded in fasteners break off. You have to remove the entire dash, a-pillar covers, instrument pod and radio to get to the right hand nylon screw. A one dollar screw and a $50. part but it is a minimum of four hours by the dealer and six hours for you and I. The added benefit was that the pixels returned, after being gone for four years......
Old 04-25-2011, 08:01 PM
edmonem's Avatar
edmonem edmonem is offline
Mein Auto: 97 528i
i get a rubbing/buzzing noise from the steering column when i rotate the wheel a couple of turns.it makes the noise during the wheel returning back to center position.it bothered me at first, but i learned to tune it out.
BMWCCA member #446696
aloha state
Old 04-25-2011, 11:43 PM
Just for the record, there are a ton of steering wheel retrofit and sensor repair DIYs listed in the bestlinks thread. One of those should explain how to take apart the steering-column covers if you still need it.
Old 04-26-2011, 07:12 PM
As always, thanks guys!!
Old 04-26-2011, 08:43 PM
Thanks Bluebee, you are right, and this link was a big help:
http://bmwtips.com/tipsntricks/Steer...eringwheel.htm
Close to the wheel, the top cover has tabs that need to be pressed inward, to release the lower cover. The covers do not come completely off, but that was enough opening, to allow me to generously spray silicone lubricant spray on all the wire bundles, fittings and parts that potentially touch each other, that was creating the buzzing sound I heard while driving on concrete pavement at freeway speeds....been driving me nuts the past couple years. Will report back in a few days if this got it or not...I am hopeful.
Old 04-04-2016, 03:31 PM
Randy Franklin Randy Franklin is offline
Mein Auto: 2012 X3 2.8
You can fix that with zip ties***128077;***127995;
