Upsizing F06 R19's from 245/40 to 245/45 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > F06 Gran Coupe (2013 - 2018)
BMW's entrance into the 4 door coupe segment to go head to head with the Audi A7 and MB CLS
Old 06-27-2019, 10:12 AM
dwmmlm dwmmlm is offline
Mein Auto: 2015 BMW 640i GC XDrive
I would imagine this has been discussed before, but I can't find any specific to the 640i GC. I am dumping the RFT's and want to go from 245/40 to 245/45 (about 1 inch larger sidewall) on my 19 inch rims. I found one guy who said he thought there may be an issue with the front suspension rubbing, but no other advice or opinions. Has anyone moved up to this tire size?
Old 06-27-2019, 10:20 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Mein Auto: 2006 X5 4.4/2013 650ix GC
I have seen this question asked many times...and I believe it is doable.
But you can also double check yourself by running it through a wheel/tire calculator. Click the following link to one of my fav wheel/tire calculators...and input the data for your existing wheel/tire...then compare it to your new setup (wheel/tire). If you have a staggered set-up (front & rear wheels & tires are different sizes)...then compare the old/new front setup...then the old/new rear setup. The site will compare and show you the specs for each one and reveal if there will be additional "poke" (outward toward the fender) and "inset" (inward toward the suspension)...as well as any increase/decrease in height and width: www.willtheyfit.com
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 06-27-2019, 10:38 AM
This is a great site. I think it will work too, just thought I'd see if there was any experiences out there with that specific combination just to give me the warm and fussy before heading to the shop.
Old 06-27-2019, 11:17 AM
I spoke with Tire Rack and they were non-committal on the fit.
Old 07-01-2019, 09:53 PM
thebmw thebmw is offline
'Fest Advisor
Mein Auto: BMWs and other fine cars
I've done it. It works and IMO, looks a little better as the wheel gap is smaller and provides a much more comfortable ride.
Old 07-02-2019, 08:34 AM
QSilver7's Avatar
Thanks for the update.
Glad it worked out for you....but you gotta know that a few pics (showing the look) would have been like a cherry on top of the sundae.
(SOLD)
Old 07-03-2019, 02:37 PM
Thanks. Do you think there's an issue with the transmission changing wheel diameter? I have AWD - Not sure if that matters.
Old 07-03-2019, 04:36 PM
'Fest Advisor
Will try to get one
'Fest Advisor
No. I don't think so as they are all the same ratios.
Old 07-05-2019, 07:50 AM
I would expect the ride to be a bit better too. Especially if you're (which I am) dropping the RFTs.
Old 07-05-2019, 09:45 AM
luigi524td luigi524td is offline
Mein Auto: '17 540xDrive; '98 Z3 2.8
Since you're (also) changing from RunFlat to GoFlat are you also carrying the spare tire for break-down situations? IF you are, the rolling radius of the slightly larger size you're intending to fit may make the use of that "spare" less than ideal -- maybe even be incompatible with BMW's AWD system.
My opinions are free - you'll get exactly what you pay for!
Current: '17 540 xDrive | '13 X1 MSport | '98 Z3 2.8
Past: '13 535xDrive|'07 530xi|'01 740i|'98 740i|'94 740i |'86 524TD
"Seek and ye shall find" - start with your owner's manual!
Click on the MrRebates logo/link for cash back savings at on-line stores like Tirerack!Mr. Rebates
Old 07-05-2019, 01:25 PM
That's a good point. I was planning on carrying a flat kit to limp to the nearest aid station in the event of a flat.
