2016 M235i run flat tires - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series & 2 Series > F22 / F23 2 Series (2014 - Current)
The 2 Series coupe is the replacement for the E82/E88 1 series coupe. Production starts in November 2013 on the 228i (N20) and M235i (N55) coupes. Look for them in dealerships in February 2014. The convertible F23 2 series will follow in the fall of 2014.
Old 11-23-2019, 05:46 PM
troutmalt troutmalt is offline
Mein Auto: 2001 750 IL
Front: Michelin Pilot Super Sport 225/40R18 (run flat) @ 32 psi
Rear: Michelin Pilot Super Sport 245/35R18 (run flat) @ 38 psi
I am constantly losing pressure in these tires, refilling, and resetting the Tire Pressure Monitor. Every 3 to 4 weeks.
Always a different tire but rears more often. I see no reason for this.
Is this symptomatic of 'run flats'?
Any one else have this problem?
Old 11-23-2019, 06:30 PM
Autoputzer Autoputzer is online now
I'm pretty sure those are non-run-flats. Michelin makes run-flat PSS's, but not in those sizes.
Tires will leak down over time. Mine leak somewhere between a half-PSI and one PSI every two to three weeks. An embedded nail or screw will cause them to leak down faster. Tire pressure goes up or down about one PSI for every ten degrees F.
Get a quality tire gauge. Meiser is the industry standard. They've about $30.
A quality hand pump is less hassle than fighting with extension cords for electric pumps. Topeak makes good pumps under their "Joe Blow" brand. Their mountain bike pump is a high-volume, low-pressure (for a bicycle) pump with a rated pressure of 75 PSI. They're about $70. That's enough to pump up a donut spare on a car.
Let the car cool off overnight. If you have a garage, it helps to open the hood, too. BMWs' engine compartments get so hot and are sealed up so tight that they still heat the front tires after twelve hours. Before sunlight hits the tires and heats some them up, check and adjust the pressures. Adjust both tires on each axle to have exactly the same pressures. Record the data: date, temperature, mileage, and pressures for each tire. Reset the TPMS.
Do the steps above in a week or two, probably after just one week if you suspect something is wrong. If the tire pressures are different on an axle, you probably have at least one embedded nail or screw. Over the decades, I've caught literally dozens of slow leaks caused by punctures this way. I've caught them early enough that I can deal with them in a convenient place and at a convenient time. Attached is a screenshot from my maintenance logbook showing how I caught a puncture early. The right-rear had lost about a fourth-PSI. I looked for, but couldn't find an embedded nail or screw. I assumed I might have mis-measured the pressure by a fourth PSI. The next time, it'd lost about a half-PSI. I removed the wheel to look for a puncture, and... Whomp! There is was!
You're much more likely to get a puncture on the back. A screw or nail laying on its side in the road is not much of a threat. But, the front tire runs over it and causes it to start tumbling down the road. If the back tire then hits it when it's anywhere near upright, you're... well... nailed, or screwed.
The proper way to repair a puncture is to remove the tire and install a "plug-patch system." It's important that the shop has a lever-less tire machine that does not touch (and scratch) the outside of your rims. A tire puncture is repairable if it's not in the outer or inner section of tread.
Think about a spare tire and a jack, since you now know you don't really have run-flats. Bimmerzone.com sells them. Actually, if you take road trips in your car you need a spare even with run-flats.
Name:	dial tire gauge.jpg
ID:	873121   Click image for larger version
Name:	joe blow mountain bike pump high volume 75 psi.jpg
ID:	873123   Click image for larger version
Name:	20191111 bmw #3 logbook entries showing slow leak in right-rear tire.jpg
ID:	873125   Click image for larger version
Name:	patch-plug tire repair.jpg
ID:	873127   Click image for larger version
Name:	plug-patch detail.jpg
Name:	repairable puncture zone.jpg
Old 11-24-2019, 06:00 PM
Autoputzer - thanks for the thoughtful reply. However ....
Those are my exact tires as written on the sidewalls.
Mine leak more often than yours.
No nail or screw puncture as different tires leak down at different rates but no one consistently low. I keep a log now.
My compressor hose can reach all the tires. More effortless for me than a hand pump.
Tires always checked when cold. TPM always reset.
I absolutely have run flat tires. Verified by Michelin and old expert at tire shop.
As soon as I have enough wear, I will switch to regular tires.
Old 11-24-2019, 06:02 PM
For any of those interested, these valve stems on these tires are not easy to get a pressure gauge on with good readings. A bit of a hassle., I have installed valve extensions and it makes for easy and accurate readings. 3/4" to 1 1/4" should do.
Old 11-24-2019, 07:20 PM
Those extensions open the OE valve. So, you're now depending on your aftermarket valve stem extensions to hold the air in.
Do your tires say "ZP" on them? That's what I've seen on Michelin run-flats, standing for "zero pressure."
A friend of mine has a F83 M4, and swears he has run-flats. But I could never find "ZP," "RFT," "RUN FLAT," or anything else on the sidewalls. He called the BMW dealer, put his phone on speaker, asked the service writer if he had run-flats. The service writer said "yes." So, then my friend was pissed at me. I punched his car into Tire Rack's tire selector, and the BMW OE PSS's came up and didn't say anything about being run-flats. So, then he was even more pissed at me... because the service writer said he had run-flats... the same service writer who said he had to buy a new tire to replace his punctured tire ($400+) instead of patching it ($30)... because it was a run-flat.
Old 11-24-2019, 08:09 PM
Here's a link to Tire Rack's list of available sizes for Michelin Pilot Super Sport ZP's:
https://www.tirerack.com/tires/tires...Super+Sport+ZP
PSS ZP's are an OE spec' tire for Corvettes.
Here's a picture of a PSS ZP with the "ZP" inside a oval right behind the "Pilot Super Sport" label on the sidewall, and "ZERO PRESSURE" right below the "ZP."
Name:	michelin pilot super sport zp.jpg
Old 11-25-2019, 01:24 AM
I have some valve stem extensions in my tool box, and went to look at them tonight. I used them to get to short valve stems on the old Honda Frau Putzer brought to the marriage. They wouldn't normally open the valve when installed. But, when some unusual adverse event occurs, the normal fault isolation process is to look first at the unusual existing conditions. I'd remove those extensions before starting to track pressure losses.
There's a technique to using a tire pressure gauge without losing pressure out of the tire. The gauge head needs to contact the valve with the exact same orientation. That's easy with a dial gauge that has an extension hose (as shown in Post #2). Also, if you're using a pencil gauge, all bets are off. Throw that thing away.
Old 11-25-2019, 10:08 PM
sttkailua sttkailua is offline
Mein Auto: M240i
Are you able to patch run flats?
My 2017 M240 came with Pirelli Centurato P7 run flats from the factory, and had a slow leak.
Took it to the dealer, and was told it had a nail.
Told me run flats cannot be patched.
Was the dealer correct?
Old 11-25-2019, 10:23 PM
Nope. They wanted $400 from you for a new tire, instead of $25 to install a plug-patch.
RFT's can't be patched if they've been driven on with no air pressure, or if the puncture is near the edge of the tread (as shown above). Running a RFT with zero pressure weakens the reinforced sidewalls.
Check your tire warranty (in the owner's manual pouch). You might have been due a new tire, or only should have paid the pro-rated cost of a new tire.
http://www.pirelli.com/mediaObject/p...atWarranty.pdf
Oops! Hawaii... Make that $500 for a new tire.
Old 11-25-2019, 11:00 PM
I had two penetrations in my right rear. Got it patched no problem. Actually it holds air better than the other 3 run flats.
Old 11-25-2019, 11:28 PM
Mein Auto: M240i
I did have tire warranty, so it $50 for deductible.
Good to know about patching the run flats.
I did get 40,000 miles on my original Pirellis!
I do 90% Freeway, donít spin, drift the tires, so it was good!
Steve
Old 11-26-2019, 04:03 PM
AndDown's Avatar
AndDown AndDown is offline
just copacetic!!!
Mein Auto: '16 428i GC
OP, check the valve stem nuts to make sure they are fastened properly. My previous F30 had an unexplainable slow leak in one tire with no nail or puncture visible. It would go down about 1-2 psi per week. At the next service, I told the SA about it and the mechanic found the lock nut was not tightened completely. No issues after that.
Dan
'01 X5 3.0 AlpWhite
'16 428i GC AlpWhite
'19 230i MSpt AlpWhite
Old 11-26-2019, 05:59 PM
John in VA John in VA is offline
Mein Auto: '74 tii / E28s / '03 530i
Check that the threaded Schrader valve in the stem is also not loose.
___________
BMW CCA #30375 - National Capital Chapter
1974 2002tii
1986 535i
2000 328i
2003 530i
2006 330ic ZHP
2015 228i M Sport
Old 11-28-2019, 12:00 PM
Thanks guys. That is great idea of checking the fitting of the Shrader valve.
Old 11-28-2019, 02:39 PM
Another leak culprit is an unevenly seated tire. I had that once, and it took literally weeks to figure it out. The clue was that the tire started vibrating once I finally got up on an interstate.
Old 11-28-2019, 06:22 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Breaking in the Pony
Mein Auto: 19 Mustang GT / 05 Tacoma
Pirelli voids any liability coverage for failures if you patch one of their runflats, so the dealer was correct in that respect. That being said, Pirelli also offers a discount on a replacement tire of the same type, based on miles on the one that gets punctured.
Prior 44 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92 / 2015 BMW M235xi xDrive F22
