Manual swap problem! - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 12-11-2019, 02:48 PM
Drives_to_fast Drives_to_fast is offline
Mein Auto: 1992 e36
Hello,
I have a 1998 328is which was automatic and now I have a manual transmission in it. I am having a problem with the check engine light. I had OTP automotive take a look at it and hes not too sure what the problem is and has never seen it.
With the automatic computer plugged in, it lights the check engine light up, but there will be no codes, read through the OBDii port or the engine bay connector. If I unplugged the automatic computer it will still throw the MIL and will give a CAN-BUS communication error with the auto ecu and the dme....
Okay, well I talked with Ken at OTP and we figured "lets flash the dme to a manual flash.. Still the exact same thing.
The car runs perfectly and all but I will not pass emissions, please any advice will help!!
Old 12-11-2019, 03:33 PM
bluptgm3 bluptgm3 is online now
Mein Auto: 99M32
I do not believe an OBDII code reader is going to be able to read transmission codes.
You going to need to remove the auto transmission code from the ECU.
Talk with the guys at Condor Speed or UUC.
Old 12-16-2019, 01:38 PM
Mein Auto: 1992 e36
Well I contacted them and both said something along the lines of "I've been doing swaps for 20 years on these and have never seen that problem...
Old 12-17-2019, 04:15 AM
M-technik-3 M-technik-3 is offline
Mein Auto: 88 M3x2 86 330i 4 e36's
20 year old car and it needs to be compliant? Odd that reflashing the ECU has not solved the issue. My last two swap cars have had nothing like this. Keep us in the loop.
Old 12-19-2019, 05:47 AM
Mein Auto: 1992 e36
I had guys at flyingwernch put a new computer in it and it solved that issue but now there are 3 more codes! We are gonna try another ecu because its throwing a vanos jamming code but there are no rattles nor is it running badly. I pulled the codes a day prior to swaping the ecu and did not have them so hopefully its just a coding problem.
Old 12-19-2019, 10:11 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
In most states, emissions compliance is forever, although the requirements are always grandfathered in some fashion. A 20-year-old car is not expected to be as clean as a 2-year-old car but it is expected to remain compliant with the standards of its day (or whatever slightly-relaxed form thereof the local government decreed "good enough").
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff (+ go-fast stuff)
BMW CCA
