won't start - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 01-22-2020, 01:09 PM
e36bmw318is e36bmw318is is offline
Mein Auto:
won't start
crank but won't start. Test feul pump ok. replace crank sensor . Test voltage on crank sensor 0 volt. Where can i look for the fuse or problem. 1997 e36 bmw 318is
Old 01-28-2020, 12:00 AM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
The crank sensor generates it's own voltage. If you're reading zero volts when the crank is turning, the sensor is dead, regardless it being new.
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 01-29-2020, 06:34 AM
spyderg0d spyderg0d is offline
Screamin demon
Mein Auto: 1995 325ic
It generates inconsistent voltage. Most meters may not be quick enough to read the pulses by the crank sensor.
Old 01-29-2020, 06:35 AM
Screamin demon
With a good scanner you should be able to read the live data and rpm while cranking. If it reads anything, its probably good.
