diesel glow plug filament stuck. - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 01-22-2020, 01:22 PM
tsotnek tsotnek is offline
Mein Auto: X5 2002 3.0d
Hello,
So basically my glow plug's screwing mechanism has broken off and only the filament remains in the glow plug's place. It is impossible to remove it I have tried with spraying tons of penetrating oils and using pliers. I have tried to remove it while the engine was very hot but it still won't come out.
Anybody know any ways to remove such filament that's stuck like that?
P.S. Please see the pictures. https://imgur.com/a/nga2Dyi
Old 01-23-2020, 09:30 AM
andrewwynn andrewwynn is online now
Mein Auto: '01 E53 X5 Black/Black
Iíve never seen a glow plug so Iím not sure what Iím looking at.
Are you showing a normal glow plug in the first two photos then in the engine just the electrode down the middle of a glow plug that broke off?
I would try a few things :
1; some impact eg a hammer tapping on the end to shock things loose
2; heat applied with a torch
3; tighten first: a tiny bit clockwise
4; break out the electrode and treat like a broken off bolt, using bolt extractor.
Keep track of all the pieces so you can be confident none are left in the cylinder. Use an otoscope or similar to view in the cylinder.
Sent from my iPhone using Tapatalk Pro
e53, filament, glow plug
