AC/Blower Issue. - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > E24 (1976 - 1989)
E24 (1976 - 1989)
The BMW 6 Series (E24) was the first variant of the 6 series produced by BMW from 1976 through 1989.
Old 10-23-2017, 12:10 PM
ilouie ilouie is offline
85 E24
Mein Auto: 1985 BMW 635 CSi
AC/Blower Issue.
Hi, I was wondering if someone has seen this issue. The Blower Motor only works on high, which is due to the Transistor. My problem is that when I turn the AC on (Push Switch in), the Blower stops working. Would that be because of the bad Transistor?. Thanks in advance.
Old 10-24-2017, 03:43 PM
85 E24
My 85 E24 has the AC Blower Motor gone. The only one working is the Heater Motor inside the Bonnet. My problem is that the Heater Blower Motor only works on high, which I pin pointed it to the Transistor right behind it. Now, I took the Heater Motor out and replaced it with the AC Motor, which it works but, the fan also works on high only. My question is, would I have to replace both, Heater and AC Transistors, or is it normally just the Heater Motor Transistor?. Thanks in advance.
Old 01-08-2018, 07:43 PM
GeorgeBush234 GeorgeBush234 is offline
Mein Auto: Passat
Do you think your blower motor might have a short to ground wire. You might need to replace
the squirrel cage.
Old 06-12-2018, 06:02 PM
ramp ramp is offline
Mein Auto: 635csi, MGA, e91 M sport
I had this issue on mine a few years ago. Went to Radio Shack spent less then two dollars. All fixed. Radio Shack is closed, but the resistor can
easily still be purchased. Good luck. Hotter days are coming.
Old 06-16-2018, 07:20 PM
Bert Poliakoff Bert Poliakoff is offline
Send a message via Yahoo to Bert Poliakoff
Mein Auto: x5
if they both work on high only it's the transistors
HTML code is Off
